  New Posts New Posts RSS Feed - 186 Horn - Throw them in the dumps?
Brutus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brutus Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 12:05pm
more boxes is your solution, just more... so build another 12 is a great option.
and because it is so obvious, use one type of driver in one type of cabinet always.
keep it simple, keep it uniform,
Edited by Brutus - 16 May 2017 at 12:07pm
bass*en*mass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 6:58pm
drivers not ideally suited to large FLHs might not survive large stacks of them either..
(rising force on the cone/motor due to "air-mass/pressure" simpy put..)?
Ruggeddave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ruggeddave Quote  Post ReplyReply Direct Link To This Post Posted: 01 June 2017 at 10:26pm
If you are using large multiples, you would be better off with the 1850 horn really
Keen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keen Quote  Post ReplyReply Direct Link To This Post Posted: 02 June 2017 at 7:36am
why? it's the same horn. different chamber size
Sapro2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sapro2 Quote  Post ReplyReply Direct Link To This Post Posted: 02 June 2017 at 9:08am
This but also the clue is in the name, the 1850 was designed for PD1850 and the 186 was designed for the PD186. Stick with your 186 horns just build more.
Splat Soundsystem
Baby Sham pram Soundsystem
Sapro - SoundCloud
https://soundcloud.com/sapro
DJ Sapro. West country free party DJ and Producer.
Mikkel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikkel Quote  Post ReplyReply Direct Link To This Post Posted: 02 June 2017 at 11:37am
precision devices 186 (for which the 186 horn was designed around) isnt a horn driver. You'll be fine with the 18sound. With your music i dont think there will be much content below 40 hz, plus the f118 crossover recommendations are a bit funny as they certainly dont produce anything usable below 40hz anyway. As mentioned before just build more 186 horns if your happy with the sound of them.
Edit: Typo
Edited by Mikkel - 02 June 2017 at 11:43am
Dutchman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dutchman Quote  Post ReplyReply Direct Link To This Post Posted: 03 June 2017 at 10:16pm
To me 186 horns sound a bit soulless.. Maybe build lab horns, punishers, SBH?
We need more SPL!
DaLI3N CZ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaLI3N CZ Quote  Post ReplyReply Direct Link To This Post Posted: 29 December 2023 at 3:12pm
what subbass you used to get down to 20hz?
