  New Posts New Posts RSS Feed - 18sound 18” Dual Subwoofer build
ole123451 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ole123451 Quote  Post ReplyReply Direct Link To This Post Posted: 09 August 2019 at 10:31pm
What kind of speaker did you use for this subwooferbox? Did you just go with the Eighteensound 18LW3000 as they suggested?
wilidapili View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wilidapili Quote  Post ReplyReply Direct Link To This Post Posted: 15 August 2019 at 9:34pm
Yes, we used the 18TLW3000. We have made two of these subwoofers, and they sound really, really nice. However, I am starting to build a prototype for a new subwoofer design called the "Skram" by Josh Ricci, just to get a little bit more lower extension. If you are interested, I am thinking about selling both of our double 18's. I could bring them to Denmark as I will be driving there during the fall/winter months. They have barely been "driven in", and have been used for only 4 gigs, all with a Powersoft amp and with all limiters in use, so they haven't been abused in any way. DM me if you are interested. Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 15 August 2019 at 10:02pm
Skram is a 30Hz box, so i fail to see how it will go lower then the 18sound 2x18 box. And it wont be louder for sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wilidapili Quote  Post ReplyReply Direct Link To This Post Posted: 15 August 2019 at 10:11pm
The tuning can be dropped by blocking a vent. Also, we'll see the comparison regarding loudness SmileAtleast two will be louder than one 218 box, which will be about the same driver and amp cost. Also it might have nicer dimensions. I don't know what I want yet Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote ole123451 Quote  Post ReplyReply Direct Link To This Post Posted: 16 August 2019 at 12:00am
Im not sure how I send you a private message, so here you have my email:
danielpedersen650@gmail.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote wilidapili Quote  Post ReplyReply Direct Link To This Post Posted: 16 August 2019 at 12:03am
Oh yeah you cannot send private messages before having 10 or so messages on the forum. I sent you an e-mail.
DanielIt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanielIt Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2020 at 9:32am
Hey Willi...can you share your fusion file for this build? Would love to take a look at that bracing.PM me please .
Measure twice...cut once.
itskabini View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote itskabini Quote  Post ReplyReply Direct Link To This Post Posted: 06 July 2021 at 10:05am
I'd like a copy of that file too if possible. Hoping to get a few of these built soon, although might try and modify it into a single 18 design.
Edited by itskabini - 06 July 2021 at 10:06am
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 06 July 2021 at 11:14pm
Its at the 18sound web site.
Post Options Post Options   Thanks (0) Thanks(0)   Quote itskabini Quote  Post ReplyReply Direct Link To This Post Posted: 06 July 2021 at 11:18pm
I was after the fusion file with all the bracing improvements, hoping to be able to give the cabinet builder a bit more detail than just the 18Sound plans.
Also would making it into a single 18 be as simple as cutting this box in half, to effectively get two triangular vents similar to he B&C sub18
lurkz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lurkz Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2025 at 11:28am
Also after the fusion file here.
I tried to build it myself at my local makerspace with tablesaw and router, but I am no master woodworker. I've completed the build with three crosses of bracing. But all the little imperfections add up, it doesn't look great and I can't play it as loud as I'd like.
I just want to pay a CNC shop to give me the pieces all perfect-like and assemble fresh cabs.
Anyone got a copy they could share?
Sypa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2025 at 4:43pm
Don't have any fusion files or for CNC but this is a pretty easy build if you ask me and I ain't no master woodworker either . Would recommend CNC rebate tho for the starting stiffness .
Built these last year a bit modified length depth for fitting on top of two 636 mm cabs . 18sound 18lw2420 loaded.
Love the sound quality not the loudest or punchiest just a nice reflex box .
Not sure how much these freestyle braces helped, the baffle is also 30mm.
Will build a few more in the future with more extensive bracing .
Edited by Sypa - 30 June 2025 at 5:02pm
