2 amps, or 1 |
Page <12 |
djshaney
Joined: 12 May 2009 Location: middlesex Status: Offline Points: 830 |
Posted: 27 June 2010 at 11:00am |
re-read your first post, okay seeing as you aint built them yet, wouldnt bother with the 122's as theyre quite big cabs and not cheap to load.
if it was me (okay, this is what i DID build) i had 2 gsubs and 2 reflex tops (such as the x12) theyre a perfect match. |
jonny4288
Joined: 06 August 2008 Location: N.Wales (WXM) Status: Offline Points: 586 |
Posted: 27 June 2010 at 5:04pm |
wouldnt bother with mt122's for house parties, way too much spl for inside a house, would go with a relfex midtop much cheaper solution for your needs too
Edited by jonny4288 - 27 June 2010 at 5:06pm |
mt122's usb2's
cravings
Joined: 30 January 2007 Location: Ireland Status: Offline Points: 7507 |
Posted: 27 June 2010 at 5:25pm |
yeah i'd start with something like a pair of X15s, or similar. these will work as good full range cabs for house parties (loud for house parties), you can then add subs under as funds allow.. and in time, if you've enough bass to call for a pair of tops like mt122s, then you can use the x15s as dj monitors or similar, or a smaller system.
sKs01
Joined: 11 April 2008 Location: sheffield Status: Offline Points: 1744 |
Posted: 27 June 2010 at 6:31pm |
buy an ultradrive best £200 I've ever spent. heard the xti's on a variety of occasions and i'm really not a fan if you must use them get a 2000 for your tops and a 4000 on mids but go for either the xls's or get something from qsc, ev, some of the older crown stuff or crest second hand and you wont go wrong, also their really isnt any point having all that top end and no bass. buy 2 12's and the compression drivers build some x12's out of mdf and once you can afford at least 3 G-subs then it would be time to build some mt 122's as you'll actually need the efficiency, until then its just more impractical than its worth.
raffe
Posted: 28 June 2010 at 8:54am |
thanks for your help everyone :)
Page <12 |
