  New Posts New Posts RSS Feed - 2*1" comp,1*8" and 1*12"
Father-Francis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Topic: 2*1" comp,1*8" and 1*12"
    Posted: 24 May 2014 at 9:43pm
this is more for Mikey , building a cab with you 8" horn and the 12" horn would it be a waste of money ,or should one go for it ?
cause nuff designs that have or are still good are based on 8", 10", 12"
meyer MSL3
OHM HD-MH
Stasys 3 mk2
and many more !
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2014 at 9:49pm
Sometimes, simple is best.
Expensive 12", on phase "bunged", long wide flare, with expensive Neo 2", will remove need for 8"/1" drivers.
Know someone in UK with just this setup, and shames many more complex systems.
BSS LMS & Quality amps, of course. Wink
Edited by levyte357- - 24 May 2014 at 9:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2014 at 9:56pm
so you mean using like the meyer horn and redoing the bong to match the 12" being used would just do the job with a go 2"neo,
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2014 at 10:00pm
Actually, mean something like the Porn Horns.
Learnt from hearing different systems, when you spend over certain budget on 2" drivers, they both go low and high. Shocked Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2014 at 10:13pm
Pm me some info I can read Bro Cry
geoSal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote geoSal Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2014 at 10:14pm
Msl3 uses a 4''inch jbl comp which goes down to 1050hz if used with its original crossovers.So the two 12'' with the huge plug can meet each other quite easy.
Although nowadays it is quite common to use 8'' drivers to cover the gap between 12'' or 15'' and 1''-1.4'' comps, I doubt if meyer can achieve that kind of spl with low wattage drivers and old amps by choosing inserting a small cone driver between mid and hi.Maybe two 8'' drivers in horn with another phase plug could do the job but as mentioned above simple sometimes is much better.
I find the coax comps solution to be the best way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2014 at 10:31pm
Here you go... Big smile
Fiber glass phase bunged 12" horn, with matching driver.
Perfectly matched, expensive Comp & comp horn.
Quality LMS programmed to perfectly align & eq above.
Pro, quality amps, mixer.
Simple really.
Rest of us mortals have to make do with MT121 & Berry DCX.
Edited by levyte357- - 24 May 2014 at 10:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote geoSal Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2014 at 10:42pm
Sometimes ι wonder if it is worth all the extra money to reach the same outcome if were using
simple ways from the start to achieve things that already work fine all these years.
Of course it is so much easier when you have the money to try new stuff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2014 at 10:46pm
Yes boss heard you loud and clear Wink
KidCreole View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2014 at 1:37pm
15 + 8 + 1''
12 + 6.5 + 1''
12 + 1.4''
10 + 1''
Post Options Post Options   Thanks (1) Thanks(1)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2014 at 2:06pm
These 2 belong to Josh 'Dea D'beat'
he picked 2 more up yesterday and now has 4 in his new stack
Flipside uses a 1'' above his SP12's
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2014 at 7:28pm
Mykey, whats approx freq range of your 12" horns, & with which suggested drivers ?
E.g., can they work with PD123, PD121, Eminence Kappa Pro, Fane 12MB?
