  New Posts New Posts RSS Feed - 2*1" comp,1*8" and 1*12"
Father-Francis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2014 at 7:58pm
Mikey do you have a 6.5" horn to go with the 12" ????
KidCreole View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2014 at 8:25pm
I have a design I'm working on that has a 12 + 6.5 + 3x1'' all in one cab to sit above a kick and K1
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2014 at 8:31pm
Mykey, whats approx freq range of your 12" horns, & with which suggested drivers ?
E.g., can they work with PD123, PD121, Eminence Kappa Pro, Fane 12MB?
130 - 2k
yeah any of those. Just depends on how you like the sound of those drivers
PD121 was never a favourite on mid
Avatron View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Avatron Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2014 at 9:18pm
How would B&C 12PE32 perform in SP12 horn?
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2014 at 9:21pm
Originally posted by KidCreole KidCreole wrote:
130 - 2k
Clap
Will 90x40 2" flare be compatible ?
Whats HxWxD (mm) ?
Edited by levyte357- - 25 May 2014 at 9:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2014 at 12:16am
yes it's a bit more brighter than the 121 that is a bit on the dull side
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2014 at 12:35am
130 - 2k
Clap
Whats HxWxD (mm) ?
SP12 is 60 - 30
556mm W x 432mm H
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2014 at 9:10am
that sounds cool Mikey let me  know how far you get with it might just take you up on that one bro
boots-hifi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boots-hifi Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2014 at 11:53am
I use BMS 12n610 + BMS 4550's although I'm going to upgrade the 1" to BMS coaxial.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2014 at 12:05pm
very nice
corell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2014 at 6:21pm
i want to either use BMS4550 or 4590 aswell, could you comment a little bit on why you are changing? ;)
knet94 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote knet94 Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2014 at 6:43pm
BMS 4590s are the dogs danglies. 2" easily reaches down to meet 12" cone and 1" gives you all the chio and sparkle you'd ever need.
