35hz to 110hz cab |
Post Reply | Page 12> |
bcs
Registered User Joined: 27 September 2010 Status: Offline Points: 216 |
Posted: 20 January 2018 at 2:14pm |
Hi guys. I don't know if what I'm asking make sense. The music I play requires me to have a bass cab from 34/35 Hz to 105/ 110hz. I've seen a lot of boxes that drops off sharply at 40hz and wouldn't meet my requirements. Wanting to keep the cabs as a single driver for portibality. I do have a reflex dual 12 and comp for mid high I'm building atm. Ideally want it to be two sub cabs and one mid high cab a side for max 200 peeps.
Thanks guys Mike |
sn95
Registered User Joined: 10 March 2013 Location: USA Status: Offline Points: 351 |
A 18 ported box will work or a tapped horn.
osse
Registered User Joined: 26 August 2013 Location: Sverige Status: Offline Points: 84 |
The keystone will fit your need very well. It sounds very good upto about 110. Two of them will totally slam any 200 capacity party
Edited by osse - 20 January 2018 at 3:11pm |
sn95
Keystone or TH18.
bcs
Thank you guys for the feedback. I sincerely appreciate it. But the keystone cab is one ugly looking cab. Any other cab that's out there.
Mike |
bass*en*mass
..put fullface grills+foam on them - job done..
bcs
So true bass*en*mass. After looking at several designs I am leaning towards the fane 200l cab. Old school reflex and I'm sure with a phat bass line. Any opinions on this cab?
nickyburnell
Yes this is the sensible answer. Stick a Fane Prime in there if you can |
bcs
Thank you Nicky. Problem is I only have access to Faital and beyma 18p1000fe drivers. Will have to sim and adjust port size accordingly.
Mike |
bass*en*mass
sticking to a certain "design/plan" using mismatched drivers doesnt help a lot, i would prefer to sim available drivers in different cab layouts matching your goals.. ;)
nickyburnell
Just use the 200l design size. The way Fane do it is on its long side. Spin in 90 degrees and then it's taller and if you ever want to stack two (or build 4) the height is good for your tops. ALL you have to do then is sort your ports for said driver. That might even be 2 x 150mm or 3 x 100 using the best you can for port noise etc. Just done 4 x fane 15 125l from same design pages, my drivers were happy with cabs tall side up and two 100mm ports at bottom |
bcs
Thanks Nicky. You're a star.. that look like a beyma 18lx60.
Edited by bcs - 21 January 2018 at 9:37am |
