  New Posts New Posts RSS Feed - 4’ x 12"concrete sewer line for bass
ebg51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ebg51 Quote  Post ReplyReply Direct Link To This Post Topic: 4’ x 12"concrete sewer line for bass
    Posted: 27 October 2005 at 12:54pm
I heard years ago that someone had used 12 inch concrete sewer line ( NEW obviously) and mounted a 12" driver in it, for exceptional bass. It was only a rumor, of course. These lines come in 5 foot sections, so the cubic feet volume would be about right. Has anyone ever heard of this?
Timber_MG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timber_MG Quote  Post ReplyReply Direct Link To This Post Posted: 27 October 2005 at 1:14pm
look up nelson Pass's El pipeo (passlabs.com or summin, google is your friend). They use sono-tube used for casting concrete pillars.
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 27 October 2005 at 3:20pm
I've often thought of recessing bits of concrete pipe into walls/floors for subs.  Would have to watch for resonances tho, being a very regular shape.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timber_MG Quote  Post ReplyReply Direct Link To This Post Posted: 27 October 2005 at 6:34pm
dampen it and remember tha in a house there are other resonances too....often worse that the cabs'.
Tony Wilkes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 28 October 2005 at 4:10am
Back in the early days of Hi-Fi there were many designs based around the use of concrete pipes for enclosures.
One of the most popular was for the Wharfedale Super 8" driver that was mounted with the pipe standing vertical and a reflector mounted so that the mid and treble from the whizzer cone was deflected horizontally.
It would be pretty easy to put a baffle inside to breakup the standing waves if they proved to be a problem.
Tony
Edited by wilkee - 28 October 2005 at 4:11am
tb_mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 29 October 2005 at 11:27pm
The thing with a cylinder is it has one or two major resonance-they might just be out of band if you filter sharply.
