7 x HH V800 |
Page <1234 7> |
Mhamplification
Joined: 16 July 2009 Location: County Durham Status: Offline Points: 541 |
Posted: 10 December 2013 at 3:31pm |
Ive put £120 on them If I get them I will post some pics of the insides They must be worth that much only cause its only 20 miles up the road from me
mini-mad
Joined: 13 July 2012 Location: london Status: Offline Points: 6861 |
Posted: 10 December 2013 at 4:49pm |
fair play.... might be worth a bit in "installs" keeping local pubs/bars/civic halls happy.
burningbush
Joined: 25 May 2009 Location: Pictland Status: Offline Points: 5885 |
Posted: 10 December 2013 at 5:09pm |
Well the T03 should be worth something as worst case scenario.
jbl_man
Joined: 12 January 2005 Location: London. Status: Offline Points: 11308 |
Posted: 10 December 2013 at 5:50pm |
Wonder if they are even MosFet?
Pin2Hot
Joined: 01 March 2011 Location: GB Status: Offline Points: 24 |
Posted: 10 December 2013 at 6:24pm |
Jbl man I think you're on the right track.
As I remember it Metro Audio was one of C-Audios brands, they obviously built amps, but were also manufacturing talkback systems and even distributing smoke fluid! Going by the four mounting bolts on the front panel, I'd say they were the same model (CA4?) that was used for the original Avitec Beta 800 and Rauch Powerblock 44, Big laminated transformer with 4 pairs of To3 Hitachi FETs per channel, must be nearly thirty years old, after a cleanout and a recap they'd probably be good for another thirty. |
jbl_man
Posted: 10 December 2013 at 6:37pm |
Yup,i thought the graphics and layout of the front panel resembled the early Avitec Beta's. Probually good solid amps if that is the case. (C-Audio built?)
But clearly not a V800 or HH at all. |
jbl_man
Posted: 10 December 2013 at 6:43pm |
Avitec Beta 800 interior.
Muckerbarnes1
Joined: 20 March 2010 Location: Stroud Status: Offline Points: 2637 |
Posted: 10 December 2013 at 6:58pm |
I have an Avitec Beta which a a C=Audio RA3000 in a 3U case. Also have Avitec Beta 300 which was brown and is more like the above. |
Billy Dawg.
SMP
Joined: 16 March 2013 Location: East London Status: Offline Points: 1209 |
Posted: 10 December 2013 at 7:19pm |
I have lots of Rauch even PB44's none to my knowledge used lam trannies or TO3 devices but toroids and J83 K228 Flatpak only DVT 300S used TO3 I even have working yes WORKING!!! ( But SMP'd) DVT500S and they were flatpaks too 16/ch 1400W4R PER CH just another design Phil Rimmer messed up
Pin2Hot
Posted: 10 December 2013 at 8:09pm |
Hmm, I crewed on a tour in the mid eighties with an Entec supplied Martin RS1200 system that was powered by racks of powerblock 44's.
A couple of weeks later I was shown the new range of amplifiers that Avitec were having manufactured for them, I couldn't help to notice the (identical) back panels and similar front panels. I've seen the inside of plenty of the Avitec amps, but never saw the inside of the Rauch amps and assumed that they had the same internals. SMP have you got any pictures of the PB44 internals, to compare the similarities / differences, maybe your amps are newer models than the ones I remember lugging around all those years ago. |
SMP
Posted: 10 December 2013 at 8:25pm |
I can post some but they are out doing what they should at present (earning rental) but one is a floater/spare that will return lwhen it is swapped out for the amp it replaced temporarily
So will take some incidentally they use a "Heat Exchanger called a "Pinfin" the only thing Phil Rimmer/Pantechnic did get right still basically the "Hitachi" Topology just uses a "Flatpak" called "HPAK" Hitachi 2SJ50 2SK135 Die in a different package. Apparently quite a rare find and sell for over £40 each as a spare I have a 100 or so here nice new ones since 85 as well a a few boxes of TO3 Hitachi |
jbl_man
Didnt the Rauch amps have that peculiar hedgehog type heatsink?
Page <1234 7> |
