A Recone Guide |
Page <1 8910 |
Sypa
Joined: 21 February 2013 Location: Croatia Status: Offline Points: 953 |
Posted: 20 November 2015 at 2:23am |
MattStolton
Joined: 04 September 2010 Location: Walthamstow Status: Offline Points: 4207 |
Posted: 04 December 2015 at 12:52pm |
I have been using Loctite 4105, as a "black" super glue (ethyl cyanoacrylate); however, it is hideously expensive. Mostly for dustcap, or other "visible" joints, where the original was a black finish, or where the dust cap join is sort of flood filled.
Found this, and wondered if anyone had used it? Looks to be very similar spec to 4105? But 1/10 of the price!!
cravings
Joined: 30 January 2007 Location: Ireland Status: Offline Points: 7507 |
Posted: 04 December 2015 at 11:13pm |
i would welcome something 1/10th the price of the loctite one alright!
komotive
Posted: 21 March 2016 at 8:54am |
Are there any other glues people have used without issue?
guig
Joined: 17 February 2017 Location: france Status: Offline Points: 14 |
Posted: 17 February 2017 at 4:12am |
JYSE
Joined: 08 May 2021 Location: Midlands Status: Offline Points: 15 |
Posted: 08 May 2021 at 9:04am |
Is this available in PDF format
Asad Ali
Joined: 23 April 2025 Location: United Kingdom Status: Offline Points: 2 |
Posted: 29 April 2025 at 6:00am |
Good Guide
Jcman1ey
Joined: 11 June 2025 Location: Bristol Status: Offline Points: 12 |
Posted: 23 September 2025 at 7:43pm |
Thank you for this, helped a lot
Steve20131
Joined: 28 July 2013 Location: Northants Status: Offline Points: 460 |
Posted: 23 September 2025 at 10:38pm |
I use RTV black high temp sealant, £4.99/75ml. Not super cheap but strong and can be cut again in future. I use two glues, a fast dry one to test then this after to fill in gaps (takes a while to go off). Make sure it's kept air tight or will cure Edited by Steve20131 - 23 September 2025 at 10:47pm |
Jcman1ey
Posted: 02 October 2025 at 8:52am |
very useful, thanks
Coded
Joined: 03 March 2010 Location: London Status: Offline Points: 18 |
Posted: 05 October 2025 at 1:58pm |
Anyone used any good Electrovoice EVM12L aftermarket kits.? Cheers
Page <1 8910 |
