A sub that's 1460mm or more in length. :) |
Page 12> |
KonanSS
Joined: 17 August 2011 Location: Devon Status: Offline Points: 392 |
Topic: A sub that's 1460mm or more in length. :)Posted: 10 April 2014 at 6:45pm |
As above
1460mm long, by 580mm deep, Twin 18" if possible, any ideas welcome :) |
KSS - Devon based always wanting to learn more
GekoMusic94
Joined: 03 February 2010 Location: Italy Status: Offline Points: 469 |
Posted: 10 April 2014 at 6:47pm |
A big reflex ;)
https://soundcloud.com/dj-uber
bass*en*mass
Joined: 03 September 2009 Location: "unknown" Status: Offline Points: 4007 |
Posted: 10 April 2014 at 7:01pm |
Ask PauliePaul, they had some huge double 1850s reflex back in the days...
Remember some pics on here but cant tell you which thread etc.. Stretched BPHs might be easy to calculate/adopt aswell? |
flinnt45
Joined: 30 April 2013 Location: london Status: Offline Points: 111 |
Posted: 11 April 2014 at 1:56pm |
Hey, Take a look at the Decware imperial, uses double 15,s but could be adapted for 2 x 18,depends on the vas of the driver, its about the right size
studio45
Joined: 16 October 2007 Location: United Kingdom Status: Offline Points: 3881 |
Posted: 11 April 2014 at 3:45pm |
Build a double Rhino or other mini-scoop? From what PauliePaul told me that would be more like what his 2x18's were, they were more complicated than a reflex. A double mini would be a beast of a box SPL-wise and they're usually around 700 tall so the double would be around 1400 wide laid on its side. Probably a bit deeper than 580 though, more like 650.
KonanSS
Posted: 11 April 2014 at 5:37pm |
Sme good ideas comming up here. Idealy if it helps I need a fast reacting sub, as it will be used for psytrance and jungle, house techno and live bands :)
Mark James
Joined: 15 January 2006 Location: rig side Status: Offline Points: 5306 |
Posted: 12 April 2014 at 1:48am |
can you pm me a link for your b&c drivers i will get siming in a 6th order bandpass and also in a larger bandpass sub if that would be suitable? working on same principle as the em15 just tuned alot lower longer horn etc would that interest you? could make it modular so easier to move or maybey walts module horn modified might suit what you are looking for? take it this is to go with the em15s and the selenium tops yes?????
the band pass horn idea would probably be a bit like the wo
insert silly sentence here
Mark James
and i doubt a scoop will suit you tbh :_]
BeDome
Joined: 12 March 2013 Location: Indy Status: Offline Points: 32 |
Posted: 07 August 2014 at 6:49am |
Just saw this, but you have to understand that most Decware plans are created for home use and not so much professional use.
Let there be sound. Oh, and lights if you care.
Meat
Joined: 05 June 2009 Location: Manc Status: Offline Points: 1513 |
Posted: 07 August 2014 at 6:58am |
Double Rhino build in a 2x18 reflex style. Do it. That thing'll rock.
flinnt45
Posted: 07 August 2014 at 7:48am |
Hi
Understood that the majority of Decware designs are for home or car use, the exception is the imperial, if you read the articall on the site you can find reference to nightclub installs etc, the original imperial with a single 15 was used by king tubby in Jamaica, good enough for me, if you see the response chart this speaker kills all scoops stone dead. |
Mark James
Posted: 07 August 2014 at 3:04pm |
or just do a modified x1 type 6th order band pass? singles could easily be 700 and something millimeters so two side by side would dstack well???? i mean like a letter box style shouldnt be too hard to design tbh
Page 12> |
