Admark AD 80 |
Page <1 5678> |
| Author | ||
cravings
Joined: 30 January 2007 Location: Ireland Status: Offline Points: 7507 |
Posted: 07 March 2026 at 9:32am |
are they the distros blue arran used to do?
and don't the admark cool front to back, and the ffa back to front.. so hot air exhausted from the admarks will be sucked in to the ffa. keep an eye on that maybe. but look very tidy. good job. |
Joined: 02 April 2004 Location: United States Status: Offline Points: 5365 |
Posted: 07 March 2026 at 10:17am |
Thanks for that tit bit! I recall when I bought my K 30 years ago, I had an option of plugs based on the Voltage Requirements. I would not be surprised if Admark offered a no connector as an option on their models as well. Best Regards, Edited by Elliot Thompson - 07 March 2026 at 10:18am |
KDW32
Joined: 09 April 2010 Location: Green Hell Status: Offline Points: 770 |
Posted: 07 March 2026 at 2:38pm |
proper good advice |
Earplug
Joined: 03 January 2012 Location: Europe Status: Offline Points: 7752 |
Posted: 07 March 2026 at 3:37pm |
"so hot air exhausted from the admarks will be sucked in to the ffa. keep an eye on that maybe." Yes - very important point when mixing amps in a rack. |
adamb00m
Joined: 05 February 2021 Status: Offline Points: 75 |
Posted: 07 March 2026 at 4:06pm |
Penn Elcom distro- but not big enough for this combo of amps - need to replace.
And yes, you are correct on the fan flow, which I didn’t even think to check before purchasing, and I have almost cooked amps like that before - but it was a berry ep2500 and I wasn’t that worried about the warranty, so I just flipped the fans around in the case, which solved the problem and it never had heat issues again. I’m bit more cautious of doing that with the FFAs… my plan is to make some kind of air guide at the back of the rack… Once I swap the distro there will be a 1U gap between the Admarks and the FFA - which is the space I will use for the air guide. Hopefully that will keep it under control - bloody annoying though.
Edited by adamb00m - 07 March 2026 at 5:04pm |
adamb00m
Posted: 11 March 2026 at 10:32pm |
Ordered a Powercon plug (NAC3FXXB-W-L) to test if the wire will fit, it does, but it’s a tight fit, which surprises me as it the spec sheet for the plug says 2.5mm max, and the wires measure 4mm - but heyho, they are rated to 20amps, and I think that’s will cover my use - will see how we go.
Hopefully the thermal trip switches on the Penn-Elcom PDUs are happy with short peaks over 16amps per bank if ever required (changed to the 32amp PDU with 8 powercon outputs - split into two banks, with a max load of 16amps per bank).
Had an exchange with Dave at FFA regarding fan flow… he said it’s unlikely to cause any issues. I’ll still be making some kind of air guide to direct the exhaust from the AD442s down and away from the FFA intake. To be fair, even after a few hours use, the air coming out of the Admarks doesn’t feel hot, or even heated… but not given them truly hard use running all channels at 4ohm yet. Edited by adamb00m - 11 March 2026 at 10:34pm |
cravings
Posted: 12 March 2026 at 1:32am |
apologies if you've considered this.. but are you measuring wire diameter, when the figures given on cables are for cross sectional area (mm squared)?
adamb00m
Posted: 12 March 2026 at 8:09am |
Oh, yes, I’m a ‘tard
Edited by adamb00m - 12 March 2026 at 8:15am |
cravings
Posted: 12 March 2026 at 11:15am |
nope. if you go back to my earlier days on here, someone pointed this out to me too heh.
djkeet
Joined: 26 December 2011 Location: England Status: Offline Points: 465 |
Posted: 13 March 2026 at 12:23am |
So its looking like 240V 3Phase 63A min no less and on 120V 100A
Soundbite
levyte357-
Joined: 27 July 2012 Location: UK, South East Status: Offline Points: 8517 |
Posted: 13 March 2026 at 12:02pm |
Maybe we should consider, how many output devices, are in the AD80, and physical current draw/storage capacity of the PSU(s), before reading too deeply into published specs.
levyte357-
Posted: 13 March 2026 at 12:10pm |
Which is why I'm on the fence regarding the AD60, and AD80. |
Page <1 5678> |
