Advice on new 15" Horn |
Page <123> |
b grade
Joined: 05 October 2012 Location: Portland OR USA Status: Offline Points: 1333 |
Posted: 23 April 2014 at 7:40am |
You probably don't want 15 mm playing super low. you want rigid heavy wood so you don't lose energy to vibration. I know BFM uses 15mm in his folded horns, but then they are pretty extensively braced to make up for it. Personally I would take the weight, and still brace intelligently.
bitSmasher
Joined: 23 June 2012 Location: Melbourne Status: Offline Points: 2302 |
Posted: 23 April 2014 at 8:45am |
12 mm actually, and that's based around relatively low powered drivers
TONY.A.S.S.
Joined: 21 February 2007 Location: United Kingdom Status: Offline Points: 6867 |
Posted: 23 April 2014 at 9:25am |
My only observations about this Design, is that it is more or less follows the path of a Scoop Bin, with the exception of how the Speaker is loaded. So to me it looks like a scoop without the Direct radiating part. Do you think there will be an extra advantage with this design over and above the normal Scoop design. Due to compression loading, I realise it would sound different from a Scoop, but just wondering how they would perform side by side. Looks like an interesting Mod though.
all bass
Joined: 11 October 2012 Location: the Netherlands Status: Offline Points: 1845 |
Posted: 23 April 2014 at 9:43am |
It can be used as a one way bass solution. It doesn't have that inevitable dip that scoops have where the horn and the direct radiator are 180 degrees out of phase.
TONY.A.S.S.
Posted: 23 April 2014 at 9:56am |
And to give the full picture, where that dip happens, is usually outside of the Sub range. It is in mine anyway.
corell
Joined: 19 August 2013 Location: Berlin Status: Offline Points: 1159 |
Posted: 23 April 2014 at 4:44pm |
Must say for my kind of music (techno) i have never been interested in scoops at all, so did not think about it yet.
My major design goal was a one-way bass hitting 40Hz. next one was to make it as flat as possible in singles without losing the smooth graph in a stack of 4. Then i thought : why not cooling the magnet?! The folding also enables you to put wheels in the lower corner and handles in the upper one to push/pull it. My questions now would be what you guys would change and if and why you would prefer this one to WSX and similar. I really want it to be an interesting option for DIY builders, so i ask for your help as your obviously part of them. If i would make it for myself to earn money, i wouldnt do so^^ |
T-Bone
Joined: 27 December 2005 Location: Tampa, FL USA Status: Offline Points: 297 |
Posted: 23 April 2014 at 6:57pm |
Ok my previous post maybe a little too far fetch, I understand what the cab's purpose by rereading your first post. I am just curious have you simulate this design with another 15" cheaper woofer readily available here in the US like Eminence or even Dayton Pro woofers available through MCM Electronics? Just curious corell so I can build one and measure it? Thanks!
BASS, how low can you go!
corell
Posted: 23 April 2014 at 8:32pm |
send me the TSP of your intended woofer and i will check it ;)
RCF 15X401 seems to be pretty cheap for its specs i think, but if thats not available, i will check others. we will have a chat via FB ;) |
T-Bone
Posted: 24 April 2014 at 7:27pm |
Oh yeah I have always wanna try Eminence Impero 15A OR Faital Pro 15FH 1020 :
http://www.eminence.com/speakers/speaker-detail/?model=Impero_15A And http://www.faitalpro.com/en/products/LF_Loudspeakers/product_details/index.php?id=201060110 http://www.eminence.com/speakers/speaker-detail/?model=Kappa_Pro_15LF2 15LF2 is now on sale at $152 each parts-express.com Thanks corell it would be great to start something new here in the States, take care!
![]() Edited by T-Bone - 24 April 2014 at 7:46pm |
tda-audio_2
Joined: 13 February 2007 Location: United Kingdom Status: Offline Points: 37 |
Posted: 02 May 2014 at 12:25pm |
to CoreLL good job! my version front loaded -invert driver
92x92x49 . 68kg . dr. ciare1200sw |
KidCreole
Joined: 06 November 2013 Location: London (East) Status: Offline Points: 3580 |
Posted: 02 May 2014 at 1:24pm |
copying again
your copied version |
tda-audio_2
Posted: 02 May 2014 at 1:30pm |
\\\your copied version\\\\
my version -change chamber! to corell - used ciare 15.00sw! |
Page <123> |
