  New Posts New Posts RSS Feed - amping
amping
jozoraz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jozoraz Quote  Post ReplyReply Direct Link To This Post Topic: amping
    Posted: 04 March 2007 at 3:34pm
my plan is to build 4 cabinets. i will use the void v18-1000 driver. what kind of amplifier would you recommend. how woud you connect them (parallel/serial) !?
i was thinking about the void infinite7, connecting 2 speakers in parallel on each side. is that enough power ? what you think?
here are some specs:
http://www.voidaudio.com/product_detail.asp?id=31
thanks for any opinions
unclejam View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote unclejam Quote  Post ReplyReply Direct Link To This Post Posted: 04 March 2007 at 8:16pm
yeah thatle do the job sommin good
gingerbiscuit69 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gingerbiscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 05 March 2007 at 7:14am
the more power you can afford from a quality amp the better. Inf 7/8 would be perfect.
Verr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Verr Quote  Post ReplyReply Direct Link To This Post Posted: 06 March 2007 at 4:11am
I've heard 4 1850 horns with V18's powered by an Infinite 8. This ran at a contolled 4ohms and it sounded awesome. The Inf 8 is more ideal as the 7 would be put under abit of strain
Fushion Julz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fushion Julz Quote  Post ReplyReply Direct Link To This Post Posted: 07 March 2007 at 6:10am
I run 4 PD1850s from an Inf 8...plenty of power and headroom...
The Inf 8 is a superb bass/sub amp...not all that subtle or detailed for mids, but for running PD1850 horns it is superb!
FUSHION SOUNDSYSTEM
www.fushion.org.uk
Post Options Post Options   Thanks (0) Thanks(0)   Quote gingerbiscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 07 March 2007 at 9:47am
i doubt an amp with that sort of power is meant for anything other than sub/bass anyway! proper overkill on mid ect whatever your rig size!
