any designs that use a 21'' and gets 145db? |
Page 12> |
Dre collier
Joined: 20 February 2008 Location: United States Status: Offline Points: 22 |
Topic: any designs that use a 21'' and gets 145db?Posted: 20 February 2008 at 4:37am |
Hey guys I'm new to the forum. But I know alot about speakers and how to use them and their correct form. well anyway I was wondering if anybody knew any designs on a subwoofer that reach an output of 145 peak, I heard of bassmaxx and others doing this. I been thinking of using a 21'' from 18sound or beyma. but don't wanna do front loaded or scoop or bandpass. Please help!!!!!!!
PRIMETIME
mykey
Joined: 18 August 2005 Location: UK/Indonesia Status: Offline Points: 9680 |
Posted: 20 February 2008 at 5:16am |
Dre collier
Posted: 20 February 2008 at 5:26am |
I look at that before but don't know the horn design. would you know what it is?
PRIMETIME
H..
Joined: 07 August 2007 Location: Thailand Status: Offline Points: 197 |
Posted: 20 February 2008 at 9:29am |
Just call FK1 i'm sure their give out the design ....................................... NOT!
TONY.A.S.S.
Joined: 21 February 2007 Location: United Kingdom Status: Offline Points: 6867 |
Posted: 20 February 2008 at 9:25pm |
I guess the horn design on the f1 cabs hasn't really departed from the original Turbosound designs. There maybe cosmetic changes to the outside but in principal I would be surprised if they differed that much. Unless anyone knows anything different.
tb_mike
Joined: 01 October 2004 Location: New Zealand Status: Offline Points: 2744 |
Posted: 20 February 2008 at 11:01pm |
No.Compare the horn mouth area,with a 21" speaker,the speaker is far smaller.It cant move enough air.
working backwards 145dB at 1metre 145 - 30dB(~1kw) = 115dB sensitivity 1watt 1metre Note the sensitivity of typical 18 and 21" speakers,they are near 99dB at 100hz.At 50hz,its usually lower. |
Dre collier
Posted: 21 February 2008 at 12:01am |
but here in the US we dont have PD. All I can use is Beyma and 18sound 21's. so I'm leaning towards a basic folded horn design wit a 21'' most likely 18sound. Anyone ever done a folded horn design wit a 21''? |
PRIMETIME
tb_mike
Posted: 21 February 2008 at 7:30am |
Well 18sound is just as good. |
ceharden
Posted: 21 February 2008 at 12:09pm |
There is often a huge price premium on 21" drivers over 18". It can often work out better just to use two 18" rather than one 21".
jethrocker
Joined: 07 June 2006 Location: Chiapas, Mexico Status: Offline Points: 1942 |
Posted: 21 February 2008 at 3:45pm |
Or wouldn't 2x 15" give you about the same SD as 1 x 21"...?
Mark James
Joined: 15 January 2006 Location: rig side Status: Offline Points: 5306 |
Posted: 21 February 2008 at 4:09pm |
tbh i dont see any point in 21s other than " mines bigger" but they must die easily???
cant imagine a 21" being very efficient at all??? 2x15 would be more sensible, 145db is going to require a horn im sure, and a 21" loaded horn is just going to rip itself apart within 5 minute surely??? there are turbo 21" band pass horn plans about but i cant seem to see the point with them to be honest, a 21" wont have much kick and wont be as effective at going low as a similar priced stack of 18s.... |
insert silly sentence here
VECTORDJ
Joined: 11 June 2006 Location: United States Status: Offline Points: 585 |
Posted: 21 February 2008 at 4:12pm |
Hi Dre, 21" woofers are rated from 800 watts to 1000 watts AES ( a good real world rating) ( the 18sound is rated at 1500 watts but if you read the fine print it is in the 750-800 AES range). This would allow up to aprox. 135 dB at full power at 1/m in a large folded horn bin. To get to 145 dB with one woofer would mean close to 4000 watts. Your woofer would have a short life. Four 21" in large horn bins in a stack could reach 145 dB. The way to reach extreme spl is with the use of a lot of bins. Rog had posted photos of about 20 bins he used for a show about year ago. He stated he got strong response down to below 20Hz with super high output. This is the way to go. VECTORDJ / VECTORSONICS
Page 12> |
