  New Posts New Posts RSS Feed - BC horns from standard FLHs
 Post Reply Post Reply Page  123 7>
citizensc View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote citizensc Quote  Post ReplyReply Direct Link To This Post Topic: BC horns from standard FLHs
    Posted: 03 September 2020 at 4:27am
Hi all
Just continuing a conversation from another thread: https://forum.speakerplans.com/bg-horn-mk1-36hz-front-loaded-horn_topic105410.html
Here are some sims of 4 standard BG horns and 4 BG horns with a hole cut in them to form a BC horn. I think the results are interesting, especially to anyone trying to reach the low 30s with a FLH.
There was no science involved in my decision making with regards to the size, location or shape of the hole in the BC horn. I just kind made it look 'right' in my mind. In retrospect I think it may need to be larger. I guess if I try that and compare the results, that's when it becomes science.
All sims are in 2pi, 1.41v @ 2 ohm, measured from 10m with values scaled to represent a measurement from 1m.
Image of how the standard BG horns are simmed.
Image of how the BC horns are simmed.
Red=BC, Blue=standard BG
BG directivity
BCBG directivity
I think these results are interesting, solid 5hz more extension is nothing to ignore. I suspect with a larger hole, it may have slightly increased efficiency. Let me know what you think. If you want me to try anything let me know!
Edited by citizensc - 03 September 2020 at 4:42am
Post Options Post Options   Thanks (0) Thanks(0)   Quote mobiele eenheid Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2020 at 5:46am
It's definitely interesting, some thoughts.
  • Do you take into account how the hole/ mouth area is radiating into 2,0 pi for some frequencies but 4,0 pi for other frequencies
  • Partially due to cabinet stack height, partially due to the irregular hole shape with it's variable distance to the edge of the boundary loading
  • The hole looks like an eye in a pyramid, Illuminati confirmed
  • Would increasing the hole not simply decrease average horn path length if it's indeed the limiting factor with regards to efficiency
I've measured quite a few horn extensions myself, some followed the sim accurately, some behaved really different somehow. I suspect that is because of the large steps in effective surface area and different behavior to what the mind thinks the air path will be like. I would measure it and then correlate the simulation to the measurement.
Long way of saying, simulate, build, measure, repeat.
KaphaSound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KaphaSound Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2020 at 7:36am
Nice work, how did the final result here stack up against hornresp? From what I’ve been seeing Akabak seems more defined but the larger fluctuations in spl are very similar. I definitely still think 2 pi isn’t the most accurate with a face that large. Even if only 40% of the wavelength is diffracted the directivity gains there will still be noticeable, but especially in the higher sub frequencies you’ll see some extra sensitivity. My main concern now with this type of horn is group delay. Also from reading some of Danley’s comments he said the trick is in something along the lines of trying to best couple the flare rate to the flat face at the mouth (which I think just means having a slow enough increase in cross sectional area to best suit low frequencies while still expanding fast enough to almost be completely flat at the end of the horn). It’s a tricky beast, but done right I still think this design is the future of bass horns.
Jo bg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jo bg Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2020 at 10:13am
From Tom Danley in diyaudio forum:
The idea for the Boundary coupled woofers like the 415 is that the hemispheric mouth “bubble” is actually bounded by the 60 by 60 inch flat baffle but in order for that to couple to the interior horn, the interior horn has to have an end area large enough to provide something close to the needed expansion rate to mate up to the exterior expansion. At the low end, the exit hole is a minor effect compared to the radiation resistances. The up side is whatever the acoustic gain is by that coupling AND the acoustic energy because of forward directivity which reduces the spl going to the rear. Keep in mind your talking about a subwoofer where 4 or 6 would be used in a large football stadium and ones and two’s per side for loud EDM events, not a home speaker unless one wants to dry their hair with it;
The Mouth does not need to be as big as the last part of the throat, following traditional horn terminstion rules, as the real termination is the air bubble contained by the flat baffle, this comes fromt the Bc creator voice... at lower Wl the mouth is not seen and the important thing is continuity between throat and exterior. At higher and smaller Wls where the mouth is seen the size is enough from what I understand.
Interesting threads on diyaudio about Bc and its predecessor  Bdeap from some years ago.
Nice threads lately, this place seems more lively  thanks!
Edited by Jo bg - 03 September 2020 at 10:18am
doller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doller Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2020 at 10:24am
Sorry citizens sir I didn't get back to you regarding the labs.
I am thinking of junking them so not a big waste to cut a hole in them.
First problem is I have no idea how big the hole should be. How does it relate to fs? I need to put two together and measure the sq mt idge.
Next is to do a plot outside rite now would be impossible. I could do one in the workshop but what would it mean? Two labs standard and two labs bc. But as I said inside measurement. I would get wholey flamed for that on this forum.
As always good work sir.
Remember four labs stacked like that would be 2.4 mtrs high, about. not possible I think two at a time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote citizensc Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2020 at 11:25am
This sim takes things in to account the same way, putting the cab on the ground in a big open field and measuring them does. By 2pi, I mean its sitting on an infinite plane rather than floating in space. The mic array is set up in a 10m arc, 10cm off the plane.
aahaha, I cant unsee that now.
If you look at that hole, then divide it by 4, the cross sectional area per cab is actually really small, <25% of the mouth area of a BG horn. If I make it ~40% of the cross sectional area, it might shorten the horn by 50mm but I doubt that will have a tangible impact compared to not properly coupling with the exterior of the cabs.
What simulation software did these simulations use? I am not saying AKABAK 3 is perfect or even that I have mastered it but it is special when compared to other software used by the DIY community. It doesn't just simulate a straight horn path, that approximates a folded horn. It simulates the actual 3d model of the horn, including the exterior panels, the shape of the driver diaphragm, all the folds, any mistakes made when folding the horn in the design phase. Maybe these sims wont perfectly overlay a real life measurement but I have some confidence that they will tell you what the impact of a change is. Eg. the BC arrangement in my above post does not improve efficiency buy does improve LF extension.
If you look in the BG horn thread, the sims there reflect this sim to a much greater degree than I was expecting. They seem to tell a similar story, increased extension with a peak in sensitivity at ~35hz
As far as AKABAK 3 goes, by 2pi, I just mean its sitting on an infinate plane. AKABAK 3 takes the exact dimensions of the exterior of the cab in to account. I dont think the halfspace/quater space discussion is relevant here as I can just model it as if its the real world cab sitting on the ground.
Are you referring to the Danley quote Jo bg posted below?
This makes me think you cant just do this to any FLH, horns with high T values may work better as the expansion rate at the end of the end of the horn will be higher.
I think there has to be a limit on how small the hole can be before it impacts efficiency and coupling. You cant put 145dB of bass through a hole the size of an orange with out it liming the amount of energy that can pass through, and I have a hard time picturing that wave coupling to a 2m x 2m baffle.
Tomorrow I am going to do some more sims, might try 3 different sizes and overlay the graphs, when I get the right size, I might try some different shapes. I will also do a visualisation of the sound pressure at the mouth, maybe we will be able to see if its coupling.
Thanks for the support, it is nice to know other people are interested in what I am working on. I'm in one of the worlds toughest lock-downs, away from my home city so I don't have a lot of better things to do with my time.
I am going to do some experimentation with hole size, if you are interested I may build a labhorn model and try it. I am also interested in what would happen if you did this with two horns, with the horn mouths on the ground. Would it still work? I might sim this too.
Sorry for the wall of text guys!
Edited by citizensc - 03 September 2020 at 11:28am
bass*en*mass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2020 at 10:48pm
if you compare the bc218 measurements you`ll see that the bc config adds little to the low corner compared to the gain in directivity due to the `boundary`involved?!
Post Options Post Options   Thanks (1) Thanks(1)   Quote citizensc Quote  Post ReplyReply Direct Link To This Post Posted: 04 September 2020 at 6:04am
I did some experimenting with cutout size.
Cross sectional area is in the key down the bottom. Seems a larger hole results in better sensitivity but increased low corner. This makes sense to me as the horn is getting slightly shorter but the hole is less restrictive.
This is 4 standard BGs in a standard config compared to the largest cutout. About 1dB improvement in sensitivity and 3hz lf extension.
Here are some top-down view maps of pressure at 63hz
Standard BG
BC 1110cm^2 cutout
BC 1400 cutout
BC1765 cutout - Key got a little messed up on this one, the values are correct, colours are just shifted.
I am thinking the BG horn is not a good candidate for boundary coupling, the pressure maps above show the standard BG horn to radiate from the whole mouth. The BC horns have a hot spot around the cutout but this reduces by ~9dB at the edge of the baffle. The 15BG100 is a relatively high Qts, this means to achieve reactance annulling via the method layed out in the letters to the editor section of the Leache paper, you need a high T-value. High T-values do not have fast flare rates at the mouth of the horn. If I find the motivation I might try to design a dedicated BC horn using the 15SW115 or even the 15DS115 then repeat this analysis on it.
Let me know what you think, does my hypothesis make sense to you?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KaphaSound Quote  Post ReplyReply Direct Link To This Post Posted: 04 September 2020 at 6:59am
Yea love this, I’d say definitely a driver with a lower qts more suited for horns would be a better shout. Also it looks as though maybe the peak spl from those radiation graphs shrinks closer to the mouth but the 3rd range or so in actually might increase in area. Just another factor to consider. I know the original purpose of this project was to use a 15” driver and I’d say very convincing results have been achieved, but I’ve slowly become more convinced that the marginal returns are seriously worth looking at with 18”s. Either way though, my bet is a lower qts will significantly help out here.
Edited by KaphaSound - 11 September 2020 at 7:02pm
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 04 September 2020 at 8:01am
Originally posted by citizensc citizensc wrote:
Standard BG
BC 1110cm^2 cutout
BC 1400 cutout
Wow, top contribution citizensc!!!! ClapVery encouraging results. I see hypercardioid dispersion patterns for the BC version Shocked
Instead of trying to achieve a 2x2 array, it would be easier to just have an horizontal array, place the horns with the mouth downwards and have the aperture on ground level.
Edited by bob4 - 04 September 2020 at 8:01am
Post Options Post Options   Thanks (1) Thanks(1)   Quote citizensc Quote  Post ReplyReply Direct Link To This Post Posted: 04 September 2020 at 10:36am
Its not that the 15bg100 isn't suited to horns, its the ideal driver for getting a cab of that volume to play as low as it does. On paper the qtc of the system (the horn + the driver) is about 0.4, making it critically damped.
The issue is that the geometry of a horn designed for it isn't ideal for boundary coupling. In the below image, you can the impact t-value has on the shape of curves, imagine those curves as the walls of a horn. The lower the t-value, the higher the expansion rate at the mouth of the horn. The goal is to have an expansion rate high enough to allow the waves to mate with the exterior of the cab... or at least that is my thinking.
taken from:https://www.grc.com/acoustics/an-introduction-to-horn-theory.pdf
Edited by citizensc - 04 September 2020 at 10:44am
Post Options Post Options   Thanks (0) Thanks(0)   Quote citizensc Quote  Post ReplyReply Direct Link To This Post Posted: 04 September 2020 at 10:38am
whoops, double posted by mistake...
Edited by citizensc - 04 September 2020 at 10:43am
