B&Cs 18NW100 compadable with the 1850hor |
Sencesync
Registered User Joined: 17 April 2005 Location: United States Status: Offline Points: 180 |
Posted: 19 April 2005 at 8:11pm |
id like to get a couple pairs of B&C's 18NW100 woofers. but as i
look at thier stats, thier EBP is 121 and thier BL is at 28, is that ok
to use for the 1850 horn, would i have better sound with the 186horn?
tb_mike
Old Croc Joined: 01 October 2004 Location: New Zealand Status: Offline Points: 2744 |
T/s specs? How do they compare to the original driver for this horn?
hepek
Registered User Joined: 22 May 2005 Location: Yugoslavia Status: Offline Points: 2 |
I am allso planing to built a pair of horn with b&c but 18ps100.
and i have a same problem like you. i don't know which horn to
use.
tb_mike
If the t/s parameters are rather similar to the one intended for the horn,it should work. |
boab
Registered User Joined: 21 June 2004 Location: Busby Status: Offline Points: 484 |
Build a 186 horn with a pzb100 they are much more suited. (As
recomended by Rog) The ps100's are for slow and low directs. check the Bls oot. boab |
ceharden
I have heard there are thermal power compression problems with using
Neo drivers such as 18NW100 in small sealed cabinets such as the rear
chambers on horns as there is a limited amount of air to cool the voice
coil and magnet. I'm assuming that drivers with large ferrite or
ceramic magnets have a greater mass to absorb the heat and thus the
increase in temperature is slower. I'd be interested if anyone
knows the truth on this.
From the investigation I've done, the 18NW100 looks like a great driver, but maybe not suited to horn boxes, been considering it for the X1 or variant perhaps. Seems that PD seem to have the horn loading drivers corner covered tho... |
hepek
hi there,
what do you think of building horn 186 with B&C 18ps76. it has high sensitivity 99db, BL26 and EBP 137 (because of high resonant frecvency 39hz). Only problem is voice coil of 3 inch. but if i don't need too mouch power, what do you think should it work? |
