Better x12 plans? |
Post Reply | Page <12 |
Risc_Terilia
Young Croc Joined: 15 December 2007 Status: Offline Points: 689 |
Nah you honestly don't need to use any trig, the angle of the inside of the back of the box to the sides will be the same as the angle of the outside of the baffle to the sides. Edited by Risc_Terilia - 09 August 2008 at 2:26am |
norty303
Ok, but that only gives the angles, and you will need the length of the sides if you want to do it without drawing it out.
norty303
I'm not sureof either the acoustic properties or air selaing qualities of the Lego construct....
ceharden
The 10,000 Points Club Joined: 05 June 2005 Location: Southampton Status: Online Points: 11776 |
You get your bit of wood, you draw out the cab on it and start cutting! Doesn't matter if you end up drifting off the plans a bit!
Dom
Old Croc Joined: 25 February 2004 Location: United Kingdom Status: Offline Points: 1700 |
I've managed for years with plans drawn on the back of envelopes. Possibly in crayon.
mullet
Registered User Joined: 29 September 2010 Status: Offline Points: 60 |
To achieve something you got to put in some effort
Bitkrusha
Registered User Joined: 10 November 2010 Location: London Status: Offline Points: 73 |
Polyester car body filler is my best friend!
11 is one louder!!
