  New Posts New Posts RSS Feed - Beware the one eyed monster!
 Post Reply Post Reply Page  123 6>
The Builder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Builder Quote  Post ReplyReply Direct Link To This Post Topic: Beware the one eyed monster!
    Posted: 22 May 2010 at 7:23pm
It just is.
Saul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Saul Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2010 at 7:31pm
i know what that is.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Builder Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2010 at 7:44pm
Bloody loud that's what that is.
It just is.
Teunos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teunos Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2010 at 10:03am
I don't. What is it?
Best regards,
Teun.
,,Diamonds are forever''
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Builder Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2010 at 10:20am
It's a symmetrical, folded, tapped horn.
Staips plans, not sure if he is releasing them.
It's only 600mm deep as well.
It just is.
staiper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote staiper Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2010 at 10:45am
It is just ~45Hz tapped horn.. Basic plan layout idea was few years old when I have designed sub for line array sys. but that cabinet was pretty much larger than this "Cyclops" prototype.
Initiated by Nick's (The Builder) topic on FSP I came to idea to make some compact (as possible) and loud "universal" -without kick bin bass cabinet to cover ~45 - 130Hz range (in multiples will do 40Hz ..even a bit under I expect).
It is posible to easily modify design to get even single starts very loud stright from 40 Hz but than cabinet size will be larger and goal of "compactness" will be a bit sacrificed.
Dimension of cabinet is H=1052mm, W=576mm (truckpack f.) , D=618mm  ~ 375liters overall which is less than most standard double 18 BR-s
I have few ideas on mind while drawing this plans .. as symetrical cone loading, position of speaker to improve usable upper end or responce, cooling..
It is possible to fit lower extension TH within same dimensions of cabinet but in that case I have to sacrifice some of ideas noted above which will drag cabinet closer to "scoop field" and than kick bin may be required what I have aimed to avoid.
BIG THANKS TO NICK for building and testing.Big smile
Running out for coffe :) ,
    Stipe
Plans:
Higher resolution PDF available on request.
Plans are free for personal use...
not for commercial production (for sale) ..just in case that someone have idea how to get obscene
rich from this plans and buy some... BMW-s (new Tongue) let me know.
edit:typos; plans added
Edited by staiper - 28 May 2010 at 1:14pm
Just do it! ..or do not.. ;)
tomschute View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomschute Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2010 at 11:01am
you never cease to amaze me Clap
any plots / sims?
www.stableaudio.co.uk
Speaker Building Services
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Builder Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2010 at 11:18am
At some point/meet/gathering I'll bring this down (up) for those who know to, "play" measuring with.
Going to buy a Fane 1000 and keep it as, "Central bin" for system or just with two spkrs on sticks.
It just is.
breakdabeat pete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote breakdabeat pete Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2010 at 2:26pm
looks interesting! hope to see some plots and maybe plans?? Wink
٩(̾●̮̮̃̾•̃̾)۶
Sinfinity View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sinfinity Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2010 at 2:44pm
Could you bring it along to CSG's amp meet ?
Matt at ukamp dot co dot uk
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Builder Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2010 at 4:50pm
Where is it?
It just is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote staiper Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2010 at 1:09pm
Plans added on first page Wink
