  New Posts New Posts RSS Feed - BMS 12" VS PD12" for hornloading.
t.geessounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote t.geessounds Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2012 at 4:27pm
i no am hi jack but wat u guys thinks about the 12nd610 for 18sound
Nick Sasquash View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick Sasquash Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2012 at 9:46pm
BMS 12N610 are my favorite horn loaded 12" Wink
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2012 at 9:59pm
If you want to go for 18Sound, the 12ND710 is the one you need.  Incredibly efficient and fantastic midrange.
Andy Kos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andy Kos Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2012 at 10:36pm
If you know the right man, PD123ER can be had for approx £100,
Dont forget PD implemented a price rise about a month ago....
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2012 at 10:58pm
12ND710 is not in production anymore as i am aware.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2012 at 11:20pm
It's just in their extended range now so there would be a slightly longer lead time.
phildat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phildat Quote  Post ReplyReply Direct Link To This Post Posted: 18 June 2012 at 9:31pm
If I remember correctly..310 ferrites got replaced by 610 neo. Same specs though?
Its just a ride.
SBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SBC Quote  Post ReplyReply Direct Link To This Post Posted: 18 June 2012 at 9:50pm
said it recently, but 123er is a great option for the money
but don't forget b&C either....
sit a 12pe32 next to a pd123er and you realise how heavy the cones are on the pd...
F.T.S.S.
Aztor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aztor Quote  Post ReplyReply Direct Link To This Post Posted: 19 June 2012 at 12:20am
dobbel post Ouch
Edited by Aztor - 19 June 2012 at 12:20am
If you could chose the PD123ER/PD121, 12pe32 or BMS 12N810. What would you choose? and why?
Price not relevant.
Tony Wilkes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 19 June 2012 at 9:15am
I doubt that a single person in the UK has heard the 810 in an MT style box so do not expect too many reliable answers.
If you are determined to use BMS then go with the 12N610.  If I was building Mt's and did not want the cost of Neo I would use the B&C's especially as I know Tony ASS would do a good deal.
Tony
kevinmcdonough View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevinmcdonough Quote  Post ReplyReply Direct Link To This Post Posted: 19 June 2012 at 10:45am
I have two of the 810's sitting here that I got from Tony last year to run some tests with, of both the mt122 style horn and the mt- 130 and then same as my THAM cabs other things came up and it got stuck on the back burner. However this summer should be better and as well as finishing off that full system plan to do some tests of both the horn mid sections and also a V18 ported horn sub to go with them and will be sticking up all the results here.
K
