Bomb Proof 4 ohm driver |
whitehousejamie
Joined: 08 March 2004 Location: United Kingdom Status: Offline Points: 1485 |
Topic: Bomb Proof 4 ohm driverPosted: 02 April 2005 at 4:54am |
Ok, i'm gonna build a couple of HD15s for small shows. Looking for a driver that i can easily get in a 4 ohm version, ideally 600 to 800watt, that will take some serious beating. Thinking about the PD1550.
Dom
Joined: 25 February 2004 Location: United Kingdom Status: Offline Points: 1700 |
Posted: 02 April 2005 at 5:45am |
Personally I can't help feeling that if you're only planning on building a couple, you should build something that works better as a single.... Why not just stick a PD186 in a reflex box about the same size as an HD15??? Simpler to build, no messing around with time alignment, will play loads lower and give a flatter response... Much as I love kick bins, even I have a pair of reflex subs for small gigs... |
