Bose 302 Cabinets plans, any body ?? please |
Post Reply | Page 12> |
Tinyzero
Registered User Joined: 19 July 2008 Location: Denmark Status: Offline Points: 11 |
Posted: 21 August 2009 at 8:12pm |
First of all, I must say I have always liked these cabinets from Bose There not going below 40 Hz acutely band pass limits to 55 Hz with active eq module But there have a fine strong bass not like horn or bass reflex systems at all I have been trying to get at set of plans for a very long time now, with out any luck Not even a picture from inside of the cabinets, are possible from google The cabinets using 2 x As I see it, its a 6 order band pass cabinets with joined bass reflex ports So any body help ! A set of plans for Bose 302 sub cabinets Edited by Tinyzero - 21 August 2009 at 8:19pm |
djyves
Young Croc Joined: 06 April 2009 Location: the Netherlands Status: Offline Points: 564 |
i am searching for the plan too
_djk_
As usual, it would help to know what brand of drive units you can purchase.
BP6A enclosures are quite sensitive to driver parameters. Edited by _djk_ - 22 August 2009 at 6:53pm |
djk
Tinyzero
Hi DJK
It is possible to buy a speaker with same T/S as the origianl speakers
so the plans / drawing af the cabinet is all i need
Tinyzero
fontaine
New Member Joined: 06 January 2010 Location: canada Status: Offline Points: 2 |
hey, i'm in canada and have a pair of 302 sleeping in my basement...... ouch!!! may be i could help out but your gonna have to be patient till i open back the cabinets to take picture'S and mesurments for you. pretty simple to built ...! i did a complete job on the suspensions in 2006 and repainted the cabinets adding also new plastic corners..... looks great now and works like new! cheers ! Francois.
djyves
I am still interested, and looking for the plan.
fontaine
i'll be in touch with you soon .....
François.
The Builder
Old Croc Joined: 03 January 2010 Status: Offline Points: 3107 |
Put Ciare drivers in them.
It just is.
musicman
Registered User Joined: 21 October 2009 Status: Offline Points: 272 |
even emmi delta 12lf works!
fellamelad
Registered User Joined: 28 May 2010 Location: midlands uk Status: Offline Points: 13 |
Hi folks justgot a pair of 302's off e-bay they have been fitted with Eminence Delta 12LFA drivers which have rubber surrounds and look very similar to the original bose drivers , i have only ever seen the deltas with paper surrounds and cant seem to find any info on the rubber surrounded ones any ideas ?
p1go
Registered User Joined: 18 January 2010 Status: Offline Points: 34 |
HI
Here's the plans:
dougsand
New Member Joined: 10 October 2010 Status: Offline Points: 1 |
Hi, Did you ever get plans for Bose 302? Thanks, Doug
