Box builders brad nail gun? |
Page <123> |
| Author | ||
KidCreole
Joined: 06 November 2013 Location: London (East) Status: Offline Points: 3580 |
Posted: 19 August 2020 at 7:27pm |
Mykey Wattco
Digbethdave
Joined: 16 November 2018 Status: Offline Points: 405 |
Posted: 23 August 2020 at 8:07pm |
The vonhaus I got from amazon, I've now used, 2 sticks of brads and it seems OK. The control for 'power' seems to do naff all. And it doesn't have a soft foot, so tends to leave a mark. Apart from that I've done what I needed it for, and now it's in stock for when I might need it again.
woody2
Posted: 23 August 2020 at 9:03pm |
Can't beat a Paslode nail gun
Digbethdave
Posted: 23 August 2020 at 9:06pm |
You don't want to be putting nails into ply
woody2
Posted: 23 August 2020 at 10:04pm |
IM65- F16 is built for it. Edited by woody2 - 23 August 2020 at 10:05pm |
Digbethdave
Posted: 23 August 2020 at 10:37pm |
OK, cheers. I'll keep that in mind. But since I've got air, and a cheapo brad gun, I'll keep with that, until I feel the need
nickyburnell
Joined: 06 February 2005 Status: Offline Points: 4408 |
Posted: 26 August 2020 at 7:46pm |
BJtheDJ
Joined: 28 November 2012 Location: Bristol Status: Offline Points: 974 |
Posted: 26 August 2020 at 8:21pm |
You left a space on the end of that URL so it didn't work, this will do the job: Edited by BJtheDJ - 26 August 2020 at 8:22pm |
I still have most of it left. |
msoundsystem
Joined: 10 November 2011 Location: wales Status: Offline Points: 630 |
Posted: 09 October 2020 at 7:13pm |
So after using the clark bandit compressor and nail gun recommended by Markie, i can confim its a fantastic piece of kit! Effortlessly fires brads into plywood/mdf. Takes a moment to set it up out the box but when its running its perfect. The only criticism is the quick release on the end of the airline to the gun leaks sometime, iv just ordered another coupling kit to put on the end so its all good.. well worth £140 tho!!!! Makes lining up and holding panels in place while putting screws in a dream! Put it through its paces building 6 cabs and 5000 brads later.
markie
Joined: 31 October 2005 Location: Sunny Liskeard. Status: Offline Points: 4568 |
Posted: 09 October 2020 at 9:17pm |
Every so often Machinemart have VAT free offers. Mine was only about £115.00 when I bought it.
Edited by markie - 09 October 2020 at 9:18pm |
citizensc
Joined: 16 October 2015 Location: Perth,Australia Status: Offline Points: 547 |
Posted: 09 October 2020 at 10:19pm |
Is it possible to build a good quality cab with out screws? In the past I have always had a second person around so one person just holds the panels while the other drives in a screw with an impact driver.
Can you just glue an staple a cab together and expect it to last? I am thinking of building then clear coating some cabs and I don't want a bunch of ugly screw heads down the side. Answer like I know nothing, I have never used a powered nail/staple gun before. |
JulianDA
Joined: 29 May 2018 Location: Soest, Germany Status: Offline Points: 156 |
Posted: 09 October 2020 at 11:57pm |
Just remember that a good glue joint is stronger than the sorrounding wood. If you can manage to get enough clamping-pressure on the joint while glueing, it will be as strong as if it had screws.
For me, the screws are just clamps for glueing and for holding the panels in the right place before the glue has set. But i have to admit, that i just leave them in there... just to ease my mind a little
Page <123> |
