carpet on HD 15 |
philip banyer
Registered User Joined: 27 October 2004 Location: Switzerland Status: Offline Points: 19 |
Posted: 05 November 2004 at 11:34am |
Can I use carpet on the of HD 15 inside and outside of the cabnet. Will this effect the sound? Many thanks PBanyer |
loophole
Registered User Joined: 02 March 2004 Status: Offline Points: 469 |
outside no, inside yes
don't carpet the inside, it looks silly and will affect the sound. to what extent, im not sure, but just don't do it, because there's no reason to. stevek (check the readers projects page) has the right idea - if you must carpet, just do the outside, and paint the inside normally. |
Andrew
Registered User Joined: 10 March 2004 Location: United Kingdom Status: Offline Points: 669 |
If the carpet is thin and dense you may get away with carpet on the inside, to match that of the outside. Try a piece inside the horn to see if it makes any difference before you glue any down. Even if it does make a small change to the sound, it may benefit from looking better, whilst still sounding pretty good.
loophole
looking better?! i think we come from two very different schools of thought andrew ;)
Andrew
If the punters think it looks good, they are more likely to think it sounds good. You can have the best system in the world, but if it looks shodily made (with Philip's profession I'd expect it to be meticulous), that will be the impression people make.
