  New Posts New Posts RSS Feed - ceramic resistor query
DMorison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2015 at 1:10pm
Originally posted by Tweeter_Box Tweeter_Box wrote:
what does the 10W actually do in a resistor?
Tells you how much power it can dissipate.
Not to be confused with the power rating of the product it's used in, as that depends on the overall circuit design.
David.
studio45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote studio45 Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2015 at 1:49pm
It's worth noting that wirewound power resistors are some of the most indestructible components; being simply a coil of nichrome wire on a heatproof stick in a ceramic casing, they "work" (ie provide the right resistance) right up until the point the wire melts, so even if they're glowing red-hot they can still be functional. I've seen units where the ceramic casing has burnt/fallen away leaving just a charred coil and former, but it still has continuity, and measures about the right number of ohms. EG the soft-start resistors in power amps are usually 25 or 50 watt units, but have to withstand a surge of several hundred watts during the start-up process; this over-rating is not a problem, and they survive many cycles.
So, basically, 1 watt of difference between an original and replacement part is no difference at all.
Tweeter_Box View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tweeter_Box Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2015 at 2:20pm
Cheers guys, perfect explanations
https://www.facebook.com/PurpleAudioRecords
Nachural View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nachural Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2015 at 3:53pm
I recently came across some passive crossovers where the ceramic resistor had survived but were glued to a plywood base which had charred badly. No wonder the customer could smell burning from the ports after a gig. LOL
it's all just cardboard and magnets really
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2015 at 4:39pm
Sound-to-Smoke feature
North Staffordshire
njw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote njw Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2015 at 6:40pm
This is what happened when the resistor in the soft start circuit of one of my C-Audios decided it had had enough;
 The rest of it was rattling around inside!LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tweeter_Box Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2015 at 6:52pm
Ouch
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tweeter_Box Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2015 at 11:59pm
So in a passive crossover board replacing a 10w 10r with a 20w 10r would actually be better as theres less chance of it failing? And wouldnt alter the attenuation levels at all?
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2015 at 12:13am
Correct. 20w is just its power handling. Iv got a box of 10,15 and 20w wire wounds somewhere.... if it says 10w use that as your 'minimum requirement' rating.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tweeter_Box Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2015 at 7:10am
Cheers for clearin that up mini
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 13 March 2015 at 7:45am
Be aware that those ceramic resistors will have a temperature rise of 250°C over ambient at their rated power.
Derated to 40% of rated power they will only be slightly warmer than boiling water!
Also keep in mind that solder melts around 180°C.
djk
stevie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevie Quote  Post ReplyReply Direct Link To This Post Posted: 13 March 2015 at 5:53pm
Resistors are responsible for more faults in speaker crossovers than any other component. For the few pence that it costs, over-specify the resistors, and space them off the board.
