  New Posts New Posts RSS Feed - Cerwin Vega B36
Cerwin Vega B36
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2007 at 10:09am
flat down to 30hz???
imo the best thing to do would be to use the vague plans available, and the age old horn responce doo dah, select an apropriate driver and "invent" the missing dimensions, ie redisign so it fits your aplication,
but to be honest all ive done is reworded your last sentence.......
you may just end up with a realy good cab though.... and its not technicaly a copy, youve just taken alot of inspiration and done a bit of work yourself......
insert silly sentence here
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2007 at 11:06am
Well, we now actually have all info required to fabricate an AB36. Have read many places 1850 loaded original AB36 will demolish 2x genuine AB36 no problem.
So after I have a cloned AB36 with suitable driver (1850 expensive and hard to get hold of), I'll take it from there.
For me the hardest part is translating hornresp figures to drawing's, not using hornresp or identifying good drivers. Have spent too much time recently doing exactly this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2007 at 6:11pm
yeah me too actualy........ hmmmmm if you think it would work then give it a whirl........ 30hz is a rather amusing thing at higher spl.........
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2007 at 7:43pm
Expanded official drawing of AB36
http://img46.imageshack.us/img46/2624/ab36rq3.jpg
Needs measurements detail from
http://groups.msn.com/_Secure/0SQAsD2IWZz!OhXV7!SEhLzaa7o856Z*RGRux9ejvJwxLZpzWj8M4UVe8Yqy7ldg5m9!2u!5aAtNIxcAdmtF06GRUmXCEkrPcWL!rGkuWNSioArrr!w5lnQ/l36.gif?dc=4675481959975824071
and front chamber measurements from here
http://img472.imageshack.us/my.php?image=cerwinvegaab36sm1.jpg
I have'nt got decent graphic s/w on this PC to do the job, can someone else do this and put it up?
Regards.
Edited by levyte357 - 03 May 2007 at 3:38am
DJ Coupé View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DJ Coupé Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2007 at 8:48pm
I have sl36 bins they are great. They seem to produce alot of bass
I run them from 30 - 80 some times 30 - 100
heinrich View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote heinrich Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2007 at 1:59am
actually I was planning to load this with SD18 p.audio but i think I will have problems fitting it inside since SD18's are deeper and larger in magnet size...
Edited by heinrich - 03 May 2007 at 2:00am
.....power is nothing without control....
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2007 at 2:54am
Without even modelling this in hornresp, I cant tell the SD18 with 5mm Xmax aint it dawg.
This baby looks like it has fairly large chamber, which dictates something like PD1850/V18-1000, OR  18LW1400/RCFL18P300/PD186/18TBX100[.
Just found the following post which should help model SL36 and identify suitable drivers "properly".
WARNING:The below post and horn measurements are also for the JE36 (Junior),  which is only 24" (62.2 cm) Deep;  NOT the "Mighty" SL36.
http://www.speakerplans.com/forum/forum_posts.asp?TID=1314&KW=vega&PN=3
Edited by levyte357 - 03 May 2007 at 3:52am
Post Options Post Options   Thanks (0) Thanks(0)   Quote heinrich Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2007 at 3:33am
well SD18 and C18 are the most available and reliable drivers that can be found here at home.....
I hope i could post some pictures of some crap type of speakers soon...
well they are marked 1000watt doubled magnet ones but when powered
with continues 800watt or so for some 4 hour or more , voice coils
deforms and burnt.......
Edited by heinrich - 05 May 2007 at 3:38am
aperrado View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aperrado Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2008 at 7:02pm
hi i need info about cerwin vega eartquake b36 inc.plans measures very  important inside measures and details  any help will be appreciated  i saw some decent pics  but inside details is hard to find
Im hard to learn but still asking
Post Options Post Options   Thanks (0) Thanks(0)   Quote aperrado Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2008 at 7:18pm
can u post more pics about this work? it look good,  where u get plans or something to do it ? i want  try to make one
Post Options Post Options   Thanks (0) Thanks(0)   Quote aperrado Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2008 at 7:22pm
[QUOTE=d-link]right well i've knocked one up today and as u can see... sexy momma
still gotta do the braces, screw and glue to bring the joins together... as for that all done
can u put a complete pics of u work it look good  where do u get plans?
Post Options Post Options   Thanks (0) Thanks(0)   Quote aperrado Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2008 at 3:31am
do u still in this forum  i ask it bcs i need help on info about this sub  u know pics,tools,dimensions,tricks evrtingh
