ciare 12sw horn |
Page <12 |
airbell ![]() Registered User ![]() Joined: 11 June 2009 Location: Berlin, Germany Status: Offline Points: 284 |
Thanks for the compliments!
Despite the simple layout it was a lot of work, i ve cutted and made everything on my own. For this first test as seen in the pics above we had only one 9kw generator and only 1 LAB Gruppen 13000! So no need to put a highpassfilter. For subs the 1 labgruppen was too little, but anyway it was still very very impressive how much power can give only 1 amp to these horns. the kick was just amazing, especially kickdrum of some classic rock songs sounded so directly and strong even at great distance. In 2012 I used them on a festival but with 4 prolines 3000 (so 4 horns per proline) and two 9kw generators. The sub was amazing, stomach shaking, low, smooth and no joke i needed no eq (other as with labgruppen where i had to push the bottom end a bit). hpf was at 30hz/24db linkwitz riley. but....i dont know if it was because of the power generators or sth else but with the prolines i really missed the upper bass - kick definition that was so much better with only 1 labgruppen fp13000!!! Unfortunately i dont have the punisher for comparison. im sure the punisher will go higher, the max. for my layout is 80hz i would say. you can cross higher but then you definitely need some eqing and resonances start to appear quickly. I would say these speakers go down to 35hz but to be fair i think the excursion goes to its limit that low, or maybe the high compression affects the output here a little bit. all in all they have a nice smooth voluminous sound as long as you dont cross them too high. the highest efficience is at about 50hz. it was insane with some tracks and the 4 prolines. and even deep low drum n bass is just fine for these horns. If you just want a lot sub beyond 40hz, you might be better with a lot of double 18s reflex or bandpass, but almost none of these constructions will have a so direct kick response like FLHs like these AND will do lots of sub ![]() nothing bad about the prolines, they are solid amps that deliver lots of current, but in the future i will try to afford 2 LABs for my horns. Im sure some other amps would do the job very well too. its just the way i want to go. Edited by airbell - 13 January 2013 at 5:01pm |
PavelP ![]() Registered User ![]() Joined: 25 March 2011 Location: Russia Status: Offline Points: 159 |
airbell, look it's not an offset horn because s1-s3 is a throat chamber 6500cm3+6000cm3=12,4L so you can make a hole for the driver as big as you want (try to simulate). By the way it's no rational to load 12" on 35Hz, you can get a better performance and surge capability from 18" in the same volume.
pavelp, WHAT please???
![]() to the 18", please check some good sub 12" horn designs before you say something like this. I think EAW Bh760 and KF940 are the most similar and if you ever heard them you d know that they are with the right setting very good speakers and a lot of sub. Edited by airbell - 13 January 2013 at 9:39pm |
Sheggy ![]() Old Croc ![]() Joined: 23 May 2008 Location: London Status: Offline Points: 1989 |
+1. What does that mean PavelP? |
tomschute ![]() Old Croc ![]() Joined: 15 May 2006 Location: Mid Wales Status: Offline Points: 1817 |
OD driver in my book. great work there! oh how i hate punishers!
Tom |
www.stableaudio.co.uk Speaker Building Services |
Ok. First of all place your sub on a floor 2,0xPi. Using 0,5xPi in any calculations of professional equipment isn't correct because 0,5xPi means that your loudspeaker is placed in a room corner. Have you seen loudspeakers in a corner?
Of course it's not an offset horn and s1-s3 will act like throat chamber 6,4L+your primary chamber 6L=12,4L. Now see your response graph. 40Hz in 383L and 98db? It's not bad, but group delay is up to 27,5ms... It's a very big delay. Then export your project in Akabak and check xmax with passive filter -- it will be very big, so maximum spl will be slightly lower. About 128db i think. http://www.avsforum.com/t/1350233/the-othorn-tapped-horn Edited by PavelP - 17 January 2013 at 6:22pm |
Mark James ![]() Old Croc ![]() ![]() Joined: 15 January 2006 Location: rig side Status: Offline Points: 5309 |
he probably simmed in 0.5pi because hes likely to use 4 or more cabs per stack 4 cabs in 2pi sims very similar to 1 cab in 0.5pi i usualy sim both ways just to check when I use horn response.....
ok you got me on OD arrangement. But it sims even better in Nd arrangement!
But yes you'd be mad to base a design like this on 2pi sims... who'd run one in open space??? Group delay isn't great around tuning frequency - big deal...? If your going with this kind of design you arn't in it for Hi-Fi bass. And Will you even notice poor group delay that low anyhow? Tom edit: Xmax looks great to 800watts if HP at 35Hz. ANd you'd be mad to put more in than that unless you like reconeing. Edited by tomschute - 17 January 2013 at 10:30pm |
So, first of all the sim at page 1 is for 8 horns standing on the floor (2pi).
in the end some parameters changed a little bit but not too much. You can use even just 1 horn per side, but indeed, you d be better off with other designs size/output wise and would need some eq. as you know horns are ment to be used in groups. in the pic you can see a total 16 of my ciare horns and if you simulate 16horn in 2pi you get an almost flat curve. it was no joke that i didnt need to boost the low end so needed no eq and had a lot of sub.also efficience is rising as for any design if used in groups.
these horns are no subbass monsters, despite you get a serious amount of low bass, surely more than with punishers, especially if you use 16 of them and power them well. but they also have a lot of overall output, are very efficient and to the group delay, there are other designs, especially bandpass, where the group delay is a loooot bigger and you have a good sound. important is that there is no big jump/difference in group delay at the higher bass frequencies where the time response is much more important. tomschute, thats exact what my experience is. ![]() a friend of mine burned his ciare 15ndh-4s horns with 1000watt, and he even has some large cooling metal sheets at the rear chamber of his horns. i considered to put 2 ciare 12sw in one of each horn to get even more low end, but i would have to change the whole design/enclosure, also one box would get too heavy for me then. one horn as it is now is actually pretty compact and i can carry and put it somewhere easily alone. thats an inportant point for me cause i dont always have some helping hands by my side. |
![]() if used in 16 xmax for 1000watt @ 36hz is 10,6mm. the ciare 12sw has 11,5mm linear xmax. ..sorry for the bad resolution! Edited by airbell - 18 January 2013 at 1:40am |
I've read all this discussion on sims and it occurred to me that simulation is probably more useful before build 16 and sit in front of them. I can't see how 16 12 sw horns would not sound good so I'll ignore the data and trust your hands on experience.
Well done on making a portable horn from a fairly awesome driver! I love this project. S Edited by Sheggy - 18 January 2013 at 5:39pm |
well simulation is good, and of course you need a starting poing also the programms today are pretty good and close to reality, but finally i did 4 prototypes and also a lot of measuring..
thanks Sheggy! always nice to hear some motivating words ![]() ![]() |
Page <12 |
