Ciare PR0310 |
GekoMusic94
Joined: 03 February 2010 Location: Italy Status: Offline Points: 469 |
Topic: Ciare PR0310Posted: 08 February 2011 at 5:56pm |
https://soundcloud.com/dj-uber
colint
Joined: 06 October 2007 Location: United Kingdom Status: Offline Points: 5260 |
Posted: 08 February 2011 at 6:59pm |
I think you'd be better of with the design below?
I've built some of these! nice little cabs but although I've kept the eighteen sound horn I've changed the drivers! I've used the P-audio 600watt 10" neo driver (SN-10MB) and a b & c comp, if you go this route then if you want to upgrade your system in the future all you need to do is add more bass & a bigger amp on the top cabs. sorry forgot to add link to the plans! the drivers are cheaper than the eighteen sound and the crossover will cope too! Edited by colint - 08 February 2011 at 7:45pm |
GekoMusic94
Posted: 08 February 2011 at 7:08pm |
Thanks for the fast reply, but why your project would be better (Actually i didn't see any plans)?
Giacomo ![]() |
colint
Posted: 08 February 2011 at 7:49pm |
Apologies I forgot to add the link? (been a long day) Now added above! simply because they handle more power will be lighter due to the neo drivers & have a better dispersion and also the fact I've heard these! they make an awful lot of noise for a small cab and sound quite good on there own too! a pair of these and 4 x MTH30's would sound very nice.
Edited by colint - 08 February 2011 at 7:50pm |
GekoMusic94
Posted: 08 February 2011 at 8:01pm |
Ok, Thanks!
pug23400
Joined: 18 January 2024 Location: Australia Status: Offline Points: 2 |
Posted: 19 September 2024 at 11:57pm |
This is a waaaaay old thread i realise but does anyone still have the plans and crossover for the Paudio 10 inch loaded FR101? Not even wayback seems to be able to help! Thanks! 🙂
pug23400
Posted: 24 September 2024 at 12:13am |
Ok ive found the plans. 😃 I wonder if this design still holds up today.. colint can you remember if you modified the slot port and crossover much? The TS parameters of the p-audio are the 18sound are reasonably different.
Edited by pug23400 - 24 September 2024 at 12:13am |
