  New Posts New Posts RSS Feed - Citronic Consoles, mixers and amps
 Post Reply Post Reply Page  <1 96979899>
vehmulski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vehmulski Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2020 at 9:08pm
doller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doller Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2021 at 9:53am
ヤフオク! - 80s ビンテージ アナログ 8chミキサー 名機 TEAC... (yahoo.co.jp)
Not a citronic I know but didn't want to start a new thread.
I just love this kinda stuff. looks mint. Not going to buy it. Never had much luck with Tascam.  Just nice looking.
PhillipDJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PhillipDJ Quote  Post ReplyReply Direct Link To This Post Posted: 27 February 2024 at 4:44am
Hi
Do you still have the Trent and Thames 2 manuals. Maybi obtain / buy copies of the manuals and service manuals please?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PhillipDJ Quote  Post ReplyReply Direct Link To This Post Posted: 16 March 2024 at 5:25am
Hi
I’m searching for the Citronic Thames II and Citronic Kennet and Trent 2 decks and mixers. Can I please buy and get posted copies.
Thank you
woody2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote woody2 Quote  Post ReplyReply Direct Link To This Post Posted: 16 March 2024 at 9:08pm
Originally posted by PhillipDJ PhillipDJ wrote:
Hi
Thank you
Try-
Double Deck Consoles From Citronic & Others - old DJs and old gear!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PhillipDJ Quote  Post ReplyReply Direct Link To This Post Posted: 17 March 2024 at 3:23pm
Hi and thank you .  I now have a Thames 2…;).  but I’ve looked through the files and 2 other sites and no Trent. I’ve also tried the AVSL Citronic sellers and they had a Trent 2 wiring manual  (perhaps for the future) and also the old Citronic 2000 amp guides…but don’t have a Trent 2 user manual. I’ve searched the web and although I’ve come across a couple of “Trent” posts….no success as yet. I don’t think there are as many about as all the other desks. It was a heavy unit, a two man lift and at the price then (approx £2000 with SL1200 Mk2 x 2 decks) probably club use and the Kennet definitely with amps built under. I’ve not see a Kennet anywhere. My Trent 2  is in like new in original, unused purple box and the whole unit simply had little part time home use.   Just need a manual to suss out the spec for the slave and variable 1/4 Jack outputs (stereo I think) to either 2 studio powered speakers in stereo or slave stereo amps (XLR inputs).
colint View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote colint Quote  Post ReplyReply Direct Link To This Post Posted: 17 March 2024 at 9:18pm
Try on the facebook group https://www.facebook.com/groups/olddjgear there is a wealth of information within the group
Post Options Post Options   Thanks (0) Thanks(0)   Quote PhillipDJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 March 2025 at 3:44am
I’m searching for any operator and service manuals for the Citronic Thames 2 and Trent disco decks. Happy to pay photocopying and postage or pdf and email please.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PhillipDJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 March 2025 at 4:37am
Thank you for the post…I’ve found them on the FB site. Much appreciated .
arpotts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote arpotts Quote  Post ReplyReply Direct Link To This Post Posted: 27 April 2025 at 8:28pm
Good evening all,
I was wondering if anybody has any information about the Citronic DC8 Lighting controller from yesteryear - 1980's I think.
I have acquired one of these recently and although I have made some progress with this (I've established which pins the supply needs to be connected to for example) but little else.
Can anybody shine any light on this (forgive the pun). I've searched the web and this brings me here. Any thoughts on this?
Many thanks,
T
Post Options Post Options   Thanks (0) Thanks(0)   Quote woody2 Quote  Post ReplyReply Direct Link To This Post Posted: 27 April 2025 at 9:49pm
It had it's own dimmer packs, have you got these?
Post Options Post Options   Thanks (0) Thanks(0)   Quote arpotts Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2025 at 1:11pm
Hi Woody,
Many thanks for your reply. I believe that the power supply for the controller was built into the dimmer packs and was connected by any one of the four 7 pin din sockets on the back of the controller.
I have examined the circuit board and I have established which pins are for the supply. I have applied 11 volts so far and have a variable output at some of the other pins when I operate some of the sliders (I need to be a little more methodical). The variable output seems to be around 0 volts to about 9 volts so I think the protocol is 0 to 10 volts although I think this would need a slightly higher supply voltage - 12 to 15 volts maybe?
If this is correct, I could use this with a dimmer pack that I have which uses 0 to 10 volts and construct a separate supply for the controller.
I would appreciate your thoughts on this.
Many Thanks,
Tony
