  New Posts New Posts RSS Feed - Cooling the speaker in 1850
Chrise View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chrise Quote  Post ReplyReply Direct Link To This Post Topic: Cooling the speaker in 1850
    Posted: 07 April 2010 at 11:39am
Hello.
I thinking about a passive cooling of the VOID V18 1000 in the 1850 Horns.
I would use heatpipes:
Did you have temperature problems with your 1850?
At which powerlevel?
Regards,Chris
Edited by Chrise - 07 April 2010 at 11:41am
[GER-User]
kallabungo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kallabungo Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2010 at 4:04pm
No temperature problems at any power level - the cabinet is designed to work with the pd1850 driver pretty well. Perhaps if you're using void drivers you'd want the loonie bin?
I think you just wanted to show off some little graphics stuff personally...
backlash View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote backlash Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2010 at 6:50pm
Void v18-1000 works fine in the 1850 horn. As said before on this forum, looney bins are a pro audio parts product - plans aren't available for them.
Sound Hire
biotec View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote biotec Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 9:45am
I never had any thermal problems with the PD1850 in the 1850 horn.
Even at pretty extreme power levels (1500w+ of music) I never blew a driver in that cab. IMO you would be trying to solve a problem which doesn't really exist.
If you are intent on trying to squeeze ever tiny little bit of SPL possible from every cab it may help, but you'd be better off being sensible with the power and getting more cabs instead.
rich_gale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rich_gale Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 11:14am
water cooling has been employed in car audio.  maybe look into water cooled pc systems too?  though as stated you shouldnt be having any cooling issues that need rectifying.
Meat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meat Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 11:54am
I thought one of the main reasons for using a PD1850 was because they're designed for low power compression.
