  New Posts New Posts RSS Feed - Court Acoustic - Black Box System
 Post Reply Post Reply Page  <1 3456>
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbl_man Quote  Post ReplyReply Direct Link To This Post Posted: 09 October 2012 at 8:02pm
Originally posted by londonavc londonavc wrote:
How much would is cost to purchase all the original JBL drivers for the mid hi box, found some empty mid hi boxes (unloaded)?
Thanks
I assume you mean with 2nd hand drivers? as the E120's aren't made anymore,so your only chance is to buy used.....i have used 2nd hand prices below.
Each box will need 2x e120 at around £100 each.....and two 2425 at approx £75 each...so around £350 a box...if you need 2402 bullets,allow an extra £50 each.
shagnasty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagnasty Quote  Post ReplyReply Direct Link To This Post Posted: 10 October 2012 at 6:48am
Originally posted by JR.junior JR.junior wrote:
Originally posted by Dub Specialist Dub Specialist wrote:
these were the original Black Court mid/hi Correct ??? or not???
Very nice cab!
Until you come to lift it!!!
2 stacks od these babies gave a 3.2Kw, took a entire face in an artic and weished near half a tonne, 290 KG of Floodlight produce about 2 -3 times the SPL, dropped lower and took 1/3 of a face in a truck pack.
Last time I was in the Marquee in Hertford they had Black box and a Pub in Milton Keynes, The Craufurd Arms runs it to great effect, just don't wanna be paying trucking on it!!!!
Big smile
csg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote csg Quote  Post ReplyReply Direct Link To This Post Posted: 10 October 2012 at 7:47am
In fairness, the black box design is 20 years older than floodlight, and one stack against one stack, the black box bottom end walks all over the turbo. Having owned both, proper black box ( not the later copies) will easily keep up with floodlight, and stacked properly will throw like flashlight.
I agree on the weight and size though - we used to have 16 full stacks - that took half our trailer...
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagnasty Quote  Post ReplyReply Direct Link To This Post Posted: 10 October 2012 at 8:27am
having run massive black box systems, like 32 boxes a side I wouldn't say the low end was particularly impressive, a TSW-718 would easy out run a black box low, probably keep up with 2.
I used stack the BB LO-LO-Mid/hi and run the bottom box under 90 hertz but even that config didn't give the lo-end of a Turbo dual 18, as for throw I would say some of the copies (W-Wayne's stuff with the JBL flares) out-threw the wooden ones but not to the point they could touch Flash with any clarity, yeah a pair of JBL 2"s will produce some SPL, but to get them musical was more of a challenge....
Were they really about in '75? I only really started using them in in '89 when EuroHire became my local PA company...
Smile
cyte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cyte Quote  Post ReplyReply Direct Link To This Post Posted: 23 October 2012 at 7:43pm
I hear Black Box 2 is coming out soon...
colint View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote colint Quote  Post ReplyReply Direct Link To This Post Posted: 23 October 2012 at 7:50pm
So Mr Court has already posted above.
cyte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cyte Quote  Post ReplyReply Direct Link To This Post Posted: 23 October 2012 at 9:16pm
Missed that...
Tocooltom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tocooltom Quote  Post ReplyReply Direct Link To This Post Posted: 24 October 2012 at 9:16am
nuclearbass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuclearbass Quote  Post ReplyReply Direct Link To This Post Posted: 24 October 2012 at 9:49am
Originally posted by SamV SamV wrote:
That must be a copy. I've seen them dropped from that height without much damage bar shifted magnets.
i was thinking this, it seems to just fall to bits "quite literally"
one life - have fun!
Force fusion pro audio
burningbush View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote burningbush Quote  Post ReplyReply Direct Link To This Post Posted: 24 October 2012 at 11:55am
djeddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 24 October 2012 at 8:23pm
But the Ramjet system has been around for a few years already.
sKitchOSB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sKitchOSB Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2013 at 6:02pm
What drivers were in the mid/tops - what is the part number and make for the 12"s ?
