  New Posts New Posts RSS Feed - crest 8001 on 13A plug
jonminns View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jonminns Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2010 at 5:43pm
I think he just is stupid!
4 ohms is for wimps
godathunder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote godathunder Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2010 at 10:07pm
cant remember ever having a problem with mine on a 13a plug although I usually only used to run at 4ohm/side
btw Im a sparky and have had to change quite a few sockets where people have drawn more than 13a through a bolt and welded the plug to the socket leaving some interesting if potentially fatal abstract art. whoever mentioned suitable breakers - 15/16a is the closest and is still only there to protect the installation, not the cable and appliance plugged into it. its more likely to be 30/32a and offer whatever youve bodged into the socket considerably less protection than youd like in an ideal world
Edited by godathunder - 19 October 2010 at 10:13pm
LOUDER THAN LOUD
Louder than loud View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Louder than loud Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2010 at 11:43pm
Grumpy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grumpy Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2010 at 11:44pm
Originally posted by Spesh Spesh wrote:
Originally posted by YoungBlood YoungBlood wrote:
6mm solid copper fuse also helps.
mr t would this be aright if distro have breakers and good mains wire ?
He wasn't being serious!!!!!!
Least he didn’t suggest using a “Widow Maker”
Don’t see as many around these daysShocked
Post Options Post Options   Thanks (0) Thanks(0)   Quote mk2_ginger_biscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 20 October 2010 at 2:40pm
sadly i saw one last week being used by a well known lighting company.....
cilla.scope View Drop Down
Legs all the way to her bottom....
Post Options Post Options   Thanks (0) Thanks(0)   Quote cilla.scope Quote  Post ReplyReply Direct Link To This Post Posted: 20 October 2010 at 6:48pm
I have one, but its for an "almost" good reason.
We occasionally have extended powercuts .. not often,  every few years it goes off for a day or so ... at which point, I throw the main breaker, and plug the generator in the shed in with a 16A BS4343-to-13A to power the freezer and a few lights.
My girlfriend thinks I'm a stalker.
Well, she's not exactly my girlfriend yet ...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grumpy Quote  Post ReplyReply Direct Link To This Post Posted: 20 October 2010 at 7:39pm
Its only half a Widow Maker thenWink
audioman1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote audioman1 Quote  Post ReplyReply Direct Link To This Post Posted: 22 October 2010 at 6:25pm
Is using 16A - 13A what you are referring to as 'Widow Maker'?
We have a couple of 16A - 4 way 13A with the trailing socket containing a 13A fuse. I don't see how this is dangerous considering it is protected by 13A. Anyone using equipment should know that a 13A bar should not exceed 13A anyway... These were bought from a lighting company with PAT certification...
Audio/ Visual System design and Installation
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grumpy Quote  Post ReplyReply Direct Link To This Post Posted: 22 October 2010 at 8:09pm
A widow maker is usually two 13 amp plugs, with leads paralleled into a single 32 amp ceeform socket.
mattd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattd Quote  Post ReplyReply Direct Link To This Post Posted: 22 October 2010 at 10:13pm
if one plug is pulled out without the other it has live pins on it- v v dangerous.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 22 October 2010 at 11:11pm
Quote We occasionally have extended powercuts .. not often, every few years it goes off for a day or so ... at which point, I throw the main breaker, and plug the generator in the shed in with a 16A BS4343-to-13A to power the freezer and a few lights.
It is a legal requirement (at least in UK) to notify your electricity supplier in writing before doing this.
North Staffordshire
Post Options Post Options   Thanks (0) Thanks(0)   Quote audioman1 Quote  Post ReplyReply Direct Link To This Post Posted: 23 October 2010 at 9:02am
ok, we definately don't use anything like that! Surely that is a suicide wish!
Do people seriously try to use contraptions like that?! Shocked
