Damping material in scoops |
Page 12> |
| Author | ||||||
JPF
Topic: Damping material in scoopsPosted: 17 September 2025 at 4:30pm |
Hi,
I am writing to see if we couls share some impresions about damping materials in scoops. There are some desings that advice to use damping material on certain areas of the chamber. Said that, dambing material in general works for mid and high frecuencies, so does it make sense to use it in a scoop which works in a range of 35-80 hz? I am asking this because I have at the moment a couple of scoops that have poliurethan foam 120 kg/m3 density and 2cm thick as a damping material and I dont know if it brings any banefit. My concerns are: - Does this material reduce the volume of the chamber? - Does it affect the tonality and how the scoop perform in the low frecuencies? - Is it worth to have it in and leave it as it is? if not what would you do, replace it by other more suitable material or just remove it? I would like to know your opinions. Many thanks in advance JPF
Tinnitus Rex
Joined: 31 October 2020 Status: Offline Points: 311 |
Posted: 17 September 2025 at 6:26pm |
I also can see no purpose for "damping" a box or cavity with wadding at below 200hz .. unless its to keep the driver warm. |
"couldn't we just like... use headphones?"
teeth
Posted: 17 September 2025 at 8:24pm |
i would recommend using 18mm plywood as a damping material
Edited by teeth - 17 September 2025 at 8:25pm |
Conanski
Joined: 26 January 2006 Location: Ottawa, Canada Status: Offline Points: 2757 |
Posted: 17 September 2025 at 10:44pm |
The function of damping materials in non sealed box sub designs is to control any out of band resonances that may result from the cabinet or driver, the audible difference between damping or no damping should be pretty subtle in most cases. There is no harm in trying a box without damping, you may or may not hear much difference.
fatfreddiescat
Joined: 15 October 2010 Location: N.E.Wales Status: Online Points: 1128 |
Posted: 18 September 2025 at 7:41am |
Can you not just remove the foam from one of them and check the result? As mentioned in the previous post. Maybe double up the damping in the other?
IIRC L Acoustics don't use damping in their K28, other manufacturers do with a slight loss of LF. If you have ever noticed, a completely empty room echoes a lot, move even a small amount of soft furnishings into it and the sound changes substantially. In this case, it is more like standing outside the room with the door ajar. With no damping, low level sounds which in themselves would be masked if they're damped, tend to be more noticable if they're allowed to ring for a significant length of time. Think upper harmonics, IMD and suspension and other mechanical sounds ringing, may or may noy not regard it as objectionable.
Edited by fatfreddiescat - 18 September 2025 at 7:54am |
Meat Substitute
Posted: 18 September 2025 at 9:19am |
Never tried scoops with wadding myself but did a test with some ES18 a few years ago. The sound was noticeably better and tighter with the wadding. In that case we added a LOT of wadding. It's probably more important for upper bass As Fatfreddiescat says above it's my understanding that the main measurable effect of wadding is in the time domain rather than in frequency response and that the effects of changing the volume of the chamber will be less than you might expect. Also agree with the comments about cooling. If the wadding affects the airflow to the vents then that's a problem and you're signing up to greater power compression and lower thermal limits. The change in thermal conductivity of the chamber is likely a very small effect in a vented chamber like a scoop where the main heat transfer out of the driver will be convective and the thermal conductivity of wood is quite bad anyway. The only way to see for sure is to try it but I think you'll want to be trying to measure time domain (waterfall/impulse) type responses rather than the frequency response to see the biggest differences.
Tinnitus Rex
Posted: 18 September 2025 at 6:13pm |
With the room filling energy of a sub bass bin at gig levels the resonances of the room would be very difficult damp with any material let alone inside a little box by using some fluffy stuff. As mentioned adding stiffening or bracing to a box would be higher on the list of micro improvements... but as the room/space that it is used in is the biggest enemy of its performance , it is the very least of its worries.
Edited by Tinnitus Rex - 18 September 2025 at 6:14pm |
Lucasdude
Joined: 16 March 2013 Location: London Status: Offline Points: 986 |
Posted: 18 September 2025 at 6:24pm |
Scoops were some of the first bins I built myself in the early 90s. The only damping I ended up using was on the panel directly behind the driver, and it was just a few mms of bitumen from my car hifi installs called "brown bread". I didn't have any measurement capabilities back then, but to me it made the most sense to damp the panel exposed to the highest energy. Maybe it was just down to my poor construction abilities, but it sounded tighter and less resonant.
Tinnitus Rex
Posted: 18 September 2025 at 7:09pm |
For mid hi the best thing would be for manufacturers to damp the chassis and magnet plate that is parallel to the back of the cone to stop inverted reflection off magnet going forward through the cone creating destructive interference ..... They dont bother much . but I can say 2" comps sound better if you damp the back cavity with dense denim fibre rather than the original foam that's glued on to most of them . But Low frequency wavelengths are way too big for this to work down at that scale .Energy absorption is directly proportional to density of material ..so bitumen or roofing rubber sheet would probably be as good as it gets .....Has anyone tried Sorbothane ?
Edited by Tinnitus Rex - 18 September 2025 at 7:17pm |
fudge22
Joined: 26 July 2022 Location: UK Status: Offline Points: 263 |
Posted: 18 September 2025 at 9:08pm |
If the resonance is out of band, there is no signal to excite the resonance, which is why the difference between with and without damping is, as you say, subtle.
If you have ever noticed, even a very small room is much larger than a typical loudspeaker, which is why you can actually fit in it, with or without furniture. If you use Sabine’s formula to calculate the approximate reverb time of a 200 ltr enclosure it comes out at about 0.15 seconds. Whether it is accurate at such small volumes I don’t know, but I doubt that reverb is a problem. At low frequencies a typical enclosure is probably too small for even resonant modes to exist so damping material will have little effect. For two way cabinets such as a 15/12 inch plus horn, mid-range resonances can have an impact on the response and damping material helps.
Completely filling the enclosure with wadding can, depending on who you speak to, lower the box Q (less resonant, more damped), making the cabinet behave as if it was slightly larger, slightly changes the speed of sound, changes the compression from being adiabatic towards being isothermal. They are all sort of intertwined.
A waterfall plot is displaying the frequency domain at a succession of discrete time intervals. When using FFT to display the response, the time and frequency domains are directly related, which is how one can be calculated from the other. Maybe somewhat pedantic, but if a certain professional sound forum can have multi-page threads because someone mentioned phase when they should have said polarity….
Possibly a placebo effect. We all convince ourselves that the latest modification has improved things.
The internet tells me that bitumen has a density of 1.25 gm/cc, concrete 2.5 gm/cc and steel 7.8 gm/cc. If absorption is directly proportional to density, leaving a steel speaker chassis uncovered should be best. For loudspeaker completeness, fibre board has a density of medium. To the OP the best way to determine the effectiveness of damping material is to experiment by measuring. It is a pain if you have to remove a drive unit every time you make a change, but one sometimes has to suffer for one’s art. Personally, I use a cut-off of 150Hz. If the loudspeaker is only used below 150Hz I don’t bother with wadding. If it goes above, and into the mid range. I measure first and if the response is uneven I experiment wadding before fiddling with the eq. |
JPF
Posted: 23 September 2025 at 10:22am |
Hi, Many thanks for your detailed and well-founded replies. Many (or most) people agree on using damping material, although the working frequencies of the box wouldn’t be directly affected. Thank you for the advice to test with and without material — that would certainly be the best approach. Here I’m posting a list of materials that are being used and recommended by some manufacturers, to hear your opinion on which would be the most suitable option:
There is quite a variety of them. What do you think about the nature of these materials, and their physical properties such as density and porosity? Manufacturers like 18 Sound recommend using high-density material such as Dacron for their box designs. At the moment I am using polyurethane foam agglomerated (~0.12 g/cm³ / 120 kg/m³) with 2 cm thickness to cover the walls of the chamber, and I’m afraid that such a high-density material could have negative effects, such as reducing the effective volume of the chamber or affecting the behavior of the lower frequencies. What are your thoughts on this? Many thanks in advance, |
levyte357-
Joined: 27 July 2012 Location: UK, South East Status: Offline Points: 8517 |
Posted: 23 September 2025 at 12:50pm |
Some of the responses in this thread, clearly illustrate, why this post should be moved to the Scoop Forum. ![]() Edited by levyte357- - 23 September 2025 at 12:51pm |
Page 12> |
