Danley BC series (BC215, BC415, BC218) |
Page <1234> |
| Author | ||
Keen
Joined: 30 May 2011 Location: Brisbane, Aus Status: Offline Points: 1271 |
Posted: 29 August 2024 at 9:59am |
build em like this, easier to load, more chamber etc
Keen
Posted: 29 August 2024 at 10:02am |
Go 4x12 each box
PTSD
Posted: 29 August 2024 at 10:34am |
Ah yea true that you would have a bigger chamber altho ya would also have a smaller horn path right needing to make the speaker a bit larger to compensate ?
PTSD
Posted: 29 August 2024 at 10:48am |
Yea I can imagine newer drivers with more power handling can be nice with more xmax. The ciare and xeleston def look not bad but the B&C response I found not very nice actually for this subwoofer application maybe I get it wrong but the 12BG fell off super early. The only thing for me would be that I especially look for sensitivity because I work with the older Crest amps I don't got as much power available as it I would have if using Powersoft& co so I like to find a nice Ballance for that.
PTSD
Posted: 29 August 2024 at 10:52am |
Fitting the driver probably not the issue next month when I got my workstation back running I will probably draw up a example. Just with the exact folding of the horn... I am not quite certain. Managing a working horn is probably not a big issue but getting the horn folding optimised I imagine is a bit more tough. But yea I am not very experienced with that haha
Keen
Posted: 31 August 2024 at 11:45am |
Yes but the loss of this first fold is much less significant in these external boundary designs because your horn path is extending outside the box. Also consider that the box is already huge and you’ll only need 2. May as well make them 1220x1220x810 in which case the horn path ends up being something like 3m even more I think. It‘s the least of your worries with this approach.
Keen
Posted: 31 August 2024 at 11:58am |
I know what you mean with the BG. Do you want to share your input data? You can change that roll off by adjusting the expansion rate of the horn. There’s also some other things worth discussing re how to simulate the inside/outside transition, horn mouth size etc
Edited by Keen - 31 August 2024 at 11:59am |
Keen
Posted: 31 August 2024 at 2:04pm |
Sorry only just read this and other posts. Thanks for sharing. Also, didn’t realise you were using Akabak not horn resp. I haven’t used akabak but would be interested to learn. Can help with horn resp though. Re optimising horn path; it’s a moot point. Rather, optimise the response in the simulation software, then build the horn to suit, etc. Cheers
Keen
Posted: 01 September 2024 at 3:13am |
Actually I have already spent many hours optimising both a 412 and 612 version of these subs and drawn the plans to suit. I draw the plans up by hand on grid graph paper to a variety of scales. The next step is to turn that plan into a virtual plan. I have never done this but perhaps you would be interested.
I could email you pictures of my plans. I’m reluctant to put stuff up on here because of those Chinese’s thief’s.
fudge22
Joined: 26 July 2022 Location: UK Status: Offline Points: 263 |
Posted: 01 September 2024 at 4:54pm |
Based on the patent image, and the manufacturer’s specifications, the “horn” path length is approximately 1.5m. How did you determine that the effective length would be 3m? Can you provide a link or some peer reviewed paper to back up your claim? The box may be huge in relation to a simple bass reflex, but given that the wavelength at 100Hz is 3.4m, in acoustic terms it is quite small. Most of the boundary effect will be due to the ground plane, something that any cabinet placed on the floor will benefit from. At bass frequencies the cabinet provides insignificant loading. |
Keen
Posted: 01 September 2024 at 10:55pm |
As I understand it the main point of this approach is that when two boxes are together with their large side facing forwards (in other words placed on their edge) and the relatively small openings placed together in the centre on the ground, the large outside front face of the combined boxes becomes part of the horn. Therefore it seems appropriate to simulate the arrangement by including this extra section. Effectively the full length from the ground to the top of the box. The effective horn mouth also dramatically increases and imo should be simulated as such. In the case of the patent image it’s 1.5m inside the box then the extra 1m for the external boundary. As I suggested building a design that’s 1220x1220x810 (to make efficient use of ply wood dimensions) which is a bigger physical box than the box in the patent, then horn path in this case would extend beyond the 3m mark. Cheers, and no sorry I don’t have any evidence to back this claim up but it does seem pretty straight forward tbh.
fudge22
Posted: 02 September 2024 at 12:43am |
The physical opening in the cabinet is too small for this design to be considered as a horn. For the radiation impedance to be to be nearly resistive the effective circumference needs to be greater than one wavelength of the lowest frequency reproduced. A square mouth can be considered to have a circumference equal to a circle of the same area. It is difficult to achieve this in a practical horn which has to be moved, hence the use of multiple horns. At low frequencies, this is more like a tuned pipe, and the end correction is usually taken as 0.6r, where r is the radius of the pipe. Where the end of the pipe is flanged (as with this design) the end correction goes up to 0.8r At best the the effective length is about 0.25m longer than the physical length. You might also consider reading up on flare rates and cutoff frequencies. If you put a drive unit in the middle of a 2m square board, you wouldn't model it as a horn with length 1m. |
Page <1234> |
