DaveyT's Mid Top |
Page <1234 13> |
| Author | ||
mykey
Joined: 18 August 2005 Location: UK/Indonesia Status: Offline Points: 9680 |
Posted: 31 March 2009 at 5:27pm |
i have tried in the past
B&C
PDFane
RCF
and that little beauty Paudio 12nb is the nats
have peole had bad experience with them then?
great sound, cheap, and super light weight
HBL and Adambomb and gang heard them in the porno horn and loved it
HBL said it kept going up and up
mykey
Posted: 31 March 2009 at 5:32pm |
can you see the problem of having different shaped cones and big ior smaller dust caps
although I was shocked that ppeople said the Bokes sounded ok
Mircea Bartic
Joined: 18 February 2005 Location: Romania Status: Offline Points: 2589 |
Posted: 31 March 2009 at 6:05pm |
I use SN12MB in some designs
I feed them with 950W per pair, and they love it ![]() |
tomschute
Joined: 15 May 2006 Location: Mid Wales Status: Offline Points: 1817 |
Posted: 31 March 2009 at 6:11pm |
looks like you've just shown what's on the tips of a few peoples tongues - including mine!
www.stableaudio.co.uk Speaker Building Services |
davey t
Joined: 11 March 2004 Location: Bristol UK Status: Offline Points: 1428 |
Posted: 31 March 2009 at 9:02pm |
thanks for the comments
as i said, i'm not trying to make a really really loud concert cab here, just something thats compact, fairly cheap, buildable and sounds good. I chose the 6" because its easier to get it to go high without a fiberglass phase bung - perhaps it wont be loud enough and i'l have to try an 8". Its a 12" because a 15" wont fit in this trap config and will struggle more to play high enough. I'l post the hornresp plots and you can take a look. i gues I wont know how it sounds though until i get buildin Mykey, have you had a look at the RCF 8" mid range neo sealed back driver? If i was going to make a fiberglass mid range horn i would use that driver! pricey though- which is why i haven't used it here. |
davey t
Posted: 31 March 2009 at 9:05pm |
extinct drivers? were you referring to me or someone else? |
doober
Joined: 03 January 2006 Location: Cornwall UK Status: Offline Points: 1123 |
Posted: 31 March 2009 at 9:47pm |
Good work!
Have you done much work on the 6" section yet? Just wondering why you chose a conical horn? It'll be much easier to construct, but does it not lose a lot of low end? I looked at that eminence driver a while ago, but it seems difficult to get hold of in the UK, like all the other suitable 6" drivers. What sort of compression ratio are you looking at? Kieran |
Blahblahblah
Mircea Bartic
Posted: 31 March 2009 at 10:03pm |
SN-12MB (200W version) is discontinued now there is a new version , please check P-audio's site www.paudiothailand.com |
davey t
Posted: 31 March 2009 at 11:29pm |
Oh yea, i knew that, i've just got 2 at home already so may aswell try with those. The low mid section should work with many different drivers. I've modeled some of the eminence neos and rcfs etc.
Timebomb
Joined: 11 October 2004 Location: Lancaster Status: Offline Points: 2763 |
Posted: 01 April 2009 at 12:25am |
Looking good davey, reminds me of the FK1 RES2 a lot.
What is the divider in the mid horn for, is it to reduce the wavelength of throat reflections? Or is it just to hold the phaze plug? Rogs has a similar centre divider in his stasys horns, ive always wonderd what its purpose was. |
minaximal
Joined: 26 September 2004 Location: United Kingdom Status: Offline Points: 1784 |
Posted: 01 April 2009 at 12:52am |
looks nice,
the closed back alpha 8mr i think? may keep up a bit better, if you needed more power. rounding over the edges of your conical horn for mouth/ baffle correction will help reduce high order modes, if going conical it could be worth trying out an oblate spheroid, or make your own to achieve smoother off axis directivity.. i too am making my mid tops atm, but its kinda too late for me to try out le cleach or spheroid flares i been reading up about, but may be of interest to you though. |
darkmatter
Joined: 26 February 2005 Location: LDN Status: Offline Points: 2419 |
Posted: 01 April 2009 at 12:59am |
I believe it's to reduce high frequency beaming. Looking good davey! |
Page <1234 13> |
