  New Posts New Posts RSS Feed - Dip Switche Settings for Stairville 10mm LED Pars
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2012 at 3:01pm
and.... just in case like.... android/itune do a dip switch calc. for your fone. yeah never know its a lite app. (no pun intended)
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2012 at 4:45pm
In this case it's not about knowing how to address the fixture (which is relatively simple binary), its how to set the correct mode, which is generally proprietary.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2012 at 4:55pm
.. oh i know that. but its nice to be able to do it in reverse wen looking at some one elses system helping them spot faults or wrongly addressed fixtures. as i said its just handy
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2012 at 5:55pm
Oh, I know its handy, its been on my phone for years
Problems with LED pars tend to be totally to do with different implementations though, with funny modes on dip 10, or non-standard numbers of dips like 12, or as with mine, 10+4.
And you can know how to set binary addresses with your eyes closed, but if you don't know the super-sekrit combo to access the DMX mode, then you're screwed.
Edited by norty303 - 08 December 2012 at 5:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2012 at 6:17pm
... drinking started early i see lol
i use to have a pinboard in my bedroom with bits of card on with "stuff not to forget" it deffo would of gone on there
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2012 at 7:03pm
Still not figured it out. Can anyone read the manual above and tell me.how to get it.into 3ch dmx? Im on a phone here
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2012 at 7:30pm
3ch dmx? do you mean address 3 or the par only uses 3 channels?
do as i said and dip 1 on all others off... it will then have address 0001 on your controller and then go nuts
James Tengo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote James Tengo Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2012 at 8:14pm
From the manual there appears to be only one dmx mode, which uses 7 channels, selected when dip switches 10, 11 and 12 are set to off. The atributes of the fixture are -
1 - Red
2 - Green
3 - Blue
4 - Macro
5 - Strobe
6 - Mode
7 - Master Dimmer
so if your unit is addressed at 1, on your controller you need ch 7 at full to get anything out of the units.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2012 at 8:19pm
ahhhhhhhhhhhh... yeah, didnt see that lol
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 09 December 2012 at 5:34am
I gave up in the end as I couldn't get it to work with my cheapo controller (ADJ RGB3C) so just used the dipswitches and stuck them on red. Interesting though that their light ouput isn't any greater than the CPC Pulse Eco Pars.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 09 December 2012 at 12:52pm
have you tried wacking all the faders up and hitting the auto button?
that controller looks a pain in the a$$... im sure its more a missunderstanding of the controller then something wrong with addressing the PAR cans... i just read through the manual.
http://www.americandj.com/pdffiles/rgb_3c.pdf
wat a pain.... can somebody shed some light here for simplistic use?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 09 December 2012 at 1:26pm
also by the looks of things it only controls 1 (bank of) fixture(s) so you'd have to put all the PARs on address (dip 1 on only) and they will all do what ever the controller tells them (or stick it on auto)
... i think... lol
