Djyves Projects CB(X)-18's, TH-SPUD, Duran, CNC |
Page <12345 36> |
djyves
Joined: 06 April 2009 Location: the Netherlands Status: Offline Points: 564 |
Posted: 09 July 2010 at 11:20am |
Where in the Netherlands can I get the four way plastic handles?
djyves
Posted: 09 July 2010 at 11:22am |
found them but a bit pricey here
staiper
Joined: 26 February 2004 Location: Croatia Status: Offline Points: 550 |
Posted: 09 July 2010 at 12:50pm |
I have also thought about that ones as elegant solution: ![]() -handles on sketch are on scale If you like it (may be not necessary but.. will be a bit easier to hold while holding horizontally) you can also move front slot handles a bit closer to front edge like on sketch and open them on front side to (like on your SketchUp 3D model) Edited by staiper - 09 July 2010 at 4:17pm |
Just do it! ..or do not.. ;)
djyves
Posted: 09 July 2010 at 10:47pm |
Didn't do much work on the CB-18 today, but I sawed the last two panels, and finished my stolpcase.
If I have time tomorrow I will router in the front handles last 2 panels putted in: ![]() |
keyvin
Joined: 08 July 2010 Location: Netherlands Status: Offline Points: 1 |
Posted: 10 July 2010 at 1:16pm |
These are just a bit cheaper:
http://www2.conrad.nl/goto.php?artikel=300590 Staiper's 2nd idea for handles is nice too... |
kiriiz
Posted: 10 July 2010 at 2:52pm |
Very interesting to compare X1 and CB-18 sound!
t.geessounds
Joined: 10 May 2010 Location: US... New york Status: Offline Points: 908 |
Posted: 10 July 2010 at 3:25pm |
might be a stupid queastion but where is the speaker hole????
djyves
Posted: 10 July 2010 at 3:47pm |
hehe... forgot it,
no ofcourse not, nothing is glued yet only biscuits, will router the hole in if i have bought a speaker.
I think I am going to buy v18-1000's, but if I don't I must router the hole bigger or smaller.
Edited by djyves - 18 July 2010 at 10:30am |
djyves
Posted: 12 July 2010 at 4:21pm |
now I can choose between the:
Void V18-1000 B&C 18tbx 100 PD 186 what would you do?
djyves
Posted: 13 July 2010 at 10:45am |
anyone?
staiper
Posted: 13 July 2010 at 3:31pm |
Hi,
I would go with 18TBX100 .. sims smooth as PD186 and have a bit more sensitivity from 70Hz up.. also a bit less cone excursion at same power than PD186 (but just a bit) .. both are specified xmax = 9mm. +18tbx100 have higher power rating wich is always good when bass is in question. :) Void V18-1000 sims peaky in this cabinet (~45Hz and 110Hz) .. but pretty same happens with simulation of original Danley TH115 which in real world appears to be flat (rally flat as line in cluster of four) .. so V18-1000 may be excellent if planing to use in stacks (4+) Edited by staiper - 13 July 2010 at 3:35pm |
djyves
Posted: 13 July 2010 at 3:37pm |
how much power will the 18tbx100 need and how much the v18-1000 before reaching/exeeding xmax. Also what program do you use to sim?
Page <12345 36> |
