  New Posts New Posts RSS Feed - Double loaded 12" or single
DJ Coupé View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DJ Coupé Quote  Post ReplyReply Direct Link To This Post Topic: Double loaded 12" or single
    Posted: 17 September 2006 at 11:44am
id like some plans for even a single loaded or double loaded 12" bass bin (jbl 2206hpl). Any ideas.
Edited by DJ Coupé - 17 September 2006 at 11:44am
Tekasis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tekasis Quote  Post ReplyReply Direct Link To This Post Posted: 25 September 2006 at 4:17pm
DJ Coupe, U must of found some by now ????
Tom Umney View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Umney Quote  Post ReplyReply Direct Link To This Post Posted: 25 September 2006 at 11:30pm
Reflex I'm guessing? They are fairly easy to design in WINISD.
You don't see many at all.As 12 inch reflex designs around are crap for serious bass.
The Eminence book has a 2x 12 inch bandpass which would give you more bass than a 2x 12 inch reflex which would be quite pathetic if used for pa.
The second last design on that page is the 2x 12 inch bandpass design.
Edited by ToXiC - 25 September 2006 at 11:39pm
CaptainCaveman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CaptainCaveman Quote  Post ReplyReply Direct Link To This Post Posted: 16 October 2006 at 7:07am
ive got a few of those boxes already made up if you interested?
CHAMPION View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CHAMPION Quote  Post ReplyReply Direct Link To This Post Posted: 16 October 2006 at 7:41am
Hi I got 4 x 15" scoop boxes forsale if your interested, Eminence design
Sticks n Stones
adambomb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote adambomb Quote  Post ReplyReply Direct Link To This Post Posted: 16 October 2006 at 8:14am
I have one of the eminence 2 x 12 BPs... ok from a distance but port-noise-tastic up close!
rich, ind.st View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rich, ind.st Quote  Post ReplyReply Direct Link To This Post Posted: 16 October 2006 at 9:40am
yea james has one of the double 12" eminence bp cabs, untill the drivers got upgraded to a wicked one as their home. they produce a reasonable ammount of bass but the port noise is ludicrous
id say that 12" reflex cabs can work for pa, i reckon 2 decent long throw 12"s in a decently designed reflex cab would sound pretty sweet, possibly be a shade faster thana 15 or 18...
music is god
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Umney Quote  Post ReplyReply Direct Link To This Post Posted: 24 October 2006 at 7:50pm
It might work if you used 2 very long excersion 12 inch drivers in a suitable tuned reflex cab. Eminence Lab 12 drivers come to mind.
 It could certainly go deep then but it still wouldn't be as loud as a horn, scoop or bandpass.
Or to achieve loud bass from a reflex it would have to be a huge enclosure for two 12 inch drivers.
moray james View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote moray james Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2006 at 12:31am
moray james
Robbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robbo Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2006 at 7:57am
About 30 years ago,FAL(no naughty comments please)manufactured a very compact mini scoop 12" plus J104 horn cabinet which used to stand about 30" high by 15" wide by 18" deep which we used to sell to mainly mobile DJs as they always used to sound amazing with an excellent punchy bass even from the relatively cheap Fane speaker within.
One of our regular DJ customers had bought four of these cabinets from us and was very pleased with them until the day his amp went DC on one side and fried one of his cabinets (luckily only using one pair on the night in question)---next day the blown cabinet duly arrived back in our shop for repair and the only reasonable 12" driver in stock was our own 12" ATC long coil bass driver with rubber surround(spare driver for some Hill bass bins). This was duly bolted in and run with some music through to test if it was OK. I wish that I had a camera at this point to capture the amazed looks on everyones faces as this little tiny cabinet proceeded to shake the shop to pieces.
Not sure if anyone has made any 12" scoops on here yet with todays hi spec drivers installed, but I would say that it would definitely be worth a try or even a 2x12" mini scoop would not be all that big to make.
Mircea Bartic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2006 at 8:28am
"Not sure if anyone has made any 12" scoops on here yet with todays hi spec drivers installed, but I would say that it would definitely be worth a try or even a 2x12" mini scoop would not be all that big to make.  "
http://www.galerie.poweraudio.ro/?path=./Back%20Loaded%20Horn%20-%20BM12-CXA/
http://www.galerie.poweraudio.ro/?path=./Popute%20Cristian%20-%20back%20loaded%20horn%20-%20Oradea/
Ex Nexus_3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robbo Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2006 at 11:39am
Thanks for that----They are far too tall though---12" scoops should work out at less than 3ft tall if they are kept in the shrinking context of a 15" scoop.
