  New Posts New Posts RSS Feed - Dual 12+ HF
Dual 12+ HF
 Post Reply Post Reply Page  <1 567
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 25 September 2022 at 4:57pm
I thought the whole point of the UMIK-1 was that it’s supplied as factory calibrated for SPL? It should really be recalibrated each time there’s a change in temperature, humidity or elevation, but as a rough guide the factory calibration should suffice.
I was always under the impression that it’s marketed as a trade off for only being able to do single channel measurements with it.
smitske96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 23 January 2024 at 12:52pm
An update regarding this project:
The V2 version has been sold eventually. I have designed a smaller version with the allocation V3, but it has several changes.
-Smaller rear volume
-Smaller frontal area
-"half circle" slots same as V1 to maximise hornlength in its footprinth
-Higher tuning compared to the 75Hz of the V2, eventhough it has less rearchamber volume it should raise sensitivity a bit from >100Hz and up.
-Handles etc.
-15mm birch ply with some 12mm bracing
-Dependent on driver, optimised phase plugs
-Bigger hatch for easier acces to the drivers
-Space for amp module like the Powersoft 4HC/HV with heatsink medium
I currently have it cnc'ed as a flatpack and unfortunately will not be going further with the project. Its just to much expense for using it maybe once or twice a year. I rather spend the money on some R&D for smaller loudspeakers etc. May someone be interested in a flatpack kit with all corresponding M10 mounts, flyware etc, pm :)
Edited by smitske96 - 23 January 2024 at 12:55pm
hectorberman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hectorberman Quote  Post ReplyReply Direct Link To This Post Posted: 23 January 2024 at 5:41pm
One of my favourite build/development threads. Sad to see this project end!
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 23 January 2024 at 8:41pm
Who knows what the future holds? Wink
Still enough planned in the future and will surely post some developements here on SP!
