  New Posts New Posts RSS Feed - DUAL 18 SELENIUM MODIFICATION
 Post Reply Post Reply Page  <1 3456>
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 16 August 2006 at 5:50am
you are verymuch right there! it isnt a sub realy is it, more an all round bass hor, stick sub under it......... thats the way im moveing in...
insert silly sentence here
tb_mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 16 August 2006 at 7:30am
So you want 186 on this horn,for some reason,and flare extension as well?
 Its just interesting how some go for little drivers and longer horn,and some go for 18"s or MULTIPLE 18"s on a short horn
Edited by tb_mike - 16 August 2006 at 7:35am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 16 August 2006 at 10:56am
the 15" version we just built is huge! [doesnt fit through a door]
100cm x 76cmx 76cm .......
they wont fit through our door,
i think your better of putting a proper sub under them..... like a lab horn [or4/6] and using a good set of mid tops, than trying to extend t he response down lower...
hmmmmmm, i like that idea a lot!!!
Heathrow_B_line View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heathrow_B_line Quote  Post ReplyReply Direct Link To This Post Posted: 16 August 2006 at 12:25pm
it takes all sorts i guess.
what i want is both of the above... big driver and longer horn.
time is running out as i want to start this by the weekend, otherwise i'll resort to the original plan of building labs and hd215s.
lets try and clarify this project specification...
1.  must use an 18" driver.  it would be nice if it was p.d. or something of similar quality/availibility.
2.  be a sub and play low freq
3.  be able to fit through a door
4.  size unlimited [see note 3]
5.  be used in groups of 6 or 8
6. max height to be no more then 2m stacked in groups
7,  width of stack unlimited
8.  not be overly power hungry
i hope this clears up things for ppl who want to help...
the size is not a problem as if it gets too big we can always split it into single 18's.
lets not worry about the extension for now.
Edited by Heathrow_B_line - 16 August 2006 at 12:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 16 August 2006 at 9:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mobiele eenheid Quote  Post ReplyReply Direct Link To This Post Posted: 17 August 2006 at 3:14am
Perhaps make the horn fit (totally) in the extension during transport. Using some parts that flip, the extension with horn will be just little larger (say 5 cm in each direction) than the original.
This way a 18" horn with 12410 cm2 moutharea, 245 cm length, 60 ltr rear chamber can be fitted into 65 x 65 x 130 cm when packed (60% of unpacked version) while still nicely braced.
COWFOOT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote COWFOOT Quote  Post ReplyReply Direct Link To This Post Posted: 17 August 2006 at 7:42am
The  18" horn that tb Mike from NZ suggested above is the simplest to build but very large and heavy. It should be a killer sub.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heathrow_B_line Quote  Post ReplyReply Direct Link To This Post Posted: 17 August 2006 at 12:55pm
i give up!
i dont have the technicaly ability to make this work so i wont waste my money trying to bodge it.
i'll go with the module horn instead....
thanks for your help mike.
i give up!
the end
gingerbiscuit69 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gingerbiscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 18 August 2006 at 10:13am
whats your facination with huge designs?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 18 August 2006 at 10:41am
same as mine... large horn generaly = very low cut off... low cut off = nice sub bass [if designed well]
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heathrow_B_line Quote  Post ReplyReply Direct Link To This Post Posted: 18 August 2006 at 1:52pm
bigger toys for bigger boys...
