  New Posts New Posts RSS Feed - dual Kilomax 18A horn pics and olans
 Post Reply Post Reply Page  <1 2345>
Disco Stu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Disco Stu Quote  Post ReplyReply Direct Link To This Post Posted: 08 March 2007 at 7:49pm
Yeah I was just generalising about the driver since as you say you tried all sorts of other boxes before this one that failed to perform adequately!
Stu
All you need to know is:
My acts:
djstefanos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djstefanos Quote  Post ReplyReply Direct Link To This Post Posted: 08 March 2007 at 9:20pm
Look at these pretty looking things
Edited by djstefanos - 08 March 2007 at 9:23pm
logsquared View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote logsquared Quote  Post ReplyReply Direct Link To This Post Posted: 09 March 2007 at 8:15am
looks wicked!  what driver are you going to use?  did you use the same fold as my drawing or is it modified?  where is the second woofer?  you will need to add supports down the center to keep the panels from vibrating.
Post Options Post Options   Thanks (0) Thanks(0)   Quote djstefanos Quote  Post ReplyReply Direct Link To This Post Posted: 09 March 2007 at 10:21am
You tell that to BASSMAXX
These aint mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote logsquared Quote  Post ReplyReply Direct Link To This Post Posted: 09 March 2007 at 12:53pm
those look a lot like my design.   i can't believe the similarity.  do you know how old the pics are?  i am wondering why the triangle cut-outs are there?  makes me feel kinda wierd.  like runing into your twin when thought you didn't have one.
must be prototypes.  with no center brace the panels are going to vibrate really bad.
Post Options Post Options   Thanks (0) Thanks(0)   Quote djstefanos Quote  Post ReplyReply Direct Link To This Post Posted: 09 March 2007 at 5:07pm
i saw them on the PSW forum some time in January.
staiper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote staiper Quote  Post ReplyReply Direct Link To This Post Posted: 10 March 2007 at 7:23am
Hello,
It is better visible on original posted image ..but do you notice those screw-dots on cabinet side. Those suggest that there is horn extension "tail" behind speaker-to-horn  "entrance" . If properly designed this can help to filter out upper bass range from horn output (cancel it by ¼ wave length reflection from blind end) and at low freq. end effectively extend horn path length.. Partially like principe in Danley tapped horns... I may be wrong..
coyote View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coyote Quote  Post ReplyReply Direct Link To This Post Posted: 10 March 2007 at 10:31pm
Originally posted by staiper staiper wrote:
Hello,
Hmmm.... I think that is obvious in Logs sketch a few post back.
Only problem I have with this design is that placement is critical.  The sides (I would think) must remain open.
What happens if its layed on its side?   I often position LAB subs just below the front edge of the stage in this way.
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2007 at 10:19pm
@logsquared
what hpf do you use with a group of four or six boxes? ie what is the minimum low frequency cutoff for these in said stacks???
insert silly sentence here
TDA-Audio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TDA-Audio Quote  Post ReplyReply Direct Link To This Post Posted: 27 July 2007 at 10:18am
Hi logsquared
please say where look plan ??
very ergonomic construction !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TDA-Audio Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2007 at 8:46am
up
heinrich View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote heinrich Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2008 at 12:17am
does any one still have the drawings of this project.........
may you repost the design please......
(need it for references)Smile
thanks..
.....power is nothing without control....
