dual Kilomax 18A horn pics and olans |
Page <1 345 |
| Author | ||||
Dougies Music
Joined: 02 September 2005 Location: London Status: Offline Points: 1104 |
Posted: 21 April 2009 at 1:01pm |
I have two C-subs at the moment loaded with Kilomax drivers and they sound ok.
I am currently building four HD15s for kick section and a couple of MT121s for mid section. You mention a single horn design, would one a side go down to 40? If so, do you have a rough sketch? Cheers Dougie
MarjanM
Joined: 10 February 2005 Location: Macedonia Status: Offline Points: 7844 |
Posted: 21 April 2009 at 4:52pm |
Dude, i hope you realize that this post is more than 2 years old.
I dont think that the original poster is still around anymore. |
twinsaudio
Posted: 16 December 2009 at 7:34am |
Hi, What's is the dimension?can you give me more photo's? Thanks
darkmatter
Joined: 26 February 2005 Location: LDN Status: Offline Points: 2419 |
Posted: 16 December 2009 at 11:40am |
Would I be right in thinking that these boxes would play a little like scoops, only the radiation from the rear of the drivers would give more of a cardioid response pattern?
Ibex
Posted: 18 December 2009 at 12:51pm |
Can someone clearify this circumstance?!
Calculated BL/sqrt(Re):
- 18S 21NLW9600: 17.76
- Void V18-1000: 14.87
- Kilomax 15A: 7.94 - LAB12: 7.24
- Ciare 12.00SW: 9.74
...these are very different values for each.
How can you make sure that a driver is suitable for FLH applications independend of it's driver size? Edited by Ibex - 18 December 2009 at 2:46pm |
rich_gale
Joined: 18 February 2008 Status: Offline Points: 2697 |
Posted: 18 December 2009 at 2:15pm |
the kilomax shares a few watered down simularities to the mccauley 6174 on paper. certainly not a 'horn driver' as far as most are concerned, but i have heared that the use of the 6174 in a bassmaxx cab is very good indeed - the bassmaxx looks very similar to this dual kilomax design.
backlash
Joined: 11 November 2008 Location: Devon Status: Offline Points: 3532 |
Posted: 18 December 2009 at 2:23pm |
The kilomax work fine in a short band pass horn, as the heat sink is on the front of the driver so cooling is ok, just. But I wouldn't suggest them in a folded horn!
Ibex
Posted: 18 December 2009 at 8:43pm |
Can't someone enlighten what's all about the mystirious BxL in FLH metioned in my last reply?!
Is it permissible to set the BL/sqrt(Re) in relation to Sd or Mms to get an comparable value for various driver sizes? |
eesbiboi
Joined: 17 September 2011 Location: cebu city Status: Offline Points: 12 |
Posted: 08 February 2026 at 5:59am |
is the plan stil available?
...chegehng discoh...
Page <1 345 |
