  New Posts New Posts RSS Feed - Easiest to build scoops? similar driver summation
Bremen_99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bremen_99 Quote  Post ReplyReply Direct Link To This Post Topic: Easiest to build scoops? similar driver summation
    Posted: 10 March 2026 at 3:30am
I have this friend and he wanted to build a system but is kinda cheap so got his drivers open box,  2tbx and 2 tbw, if he were to run them all together, would the increased group delay in scoops make the drivers difference (albeit model very similar) manifest audibly more so than loading them all in the same design of a different enclosure, ala reflex so they sum more cleanly-ier? Is he just a dunce and I should throw things at him
Also, I've heard Eminence scoops and hugo scoops might be easier ones to start with, do you have a favorite fullsize or short scoop that is something a beginner could work with?
levyte357- View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 10 March 2026 at 11:46am
I personally would only consider 18tbw100, for reflex.
18TBX100 is nothing special in a Scoop, but works in many designs, Mykey Scaled up plan, would be recommended.
Edited by levyte357- - 10 March 2026 at 11:50am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bremen_99 Quote  Post ReplyReply Direct Link To This Post Posted: 10 March 2026 at 7:21pm
I mean I've seen them sim great in horns, higher end pioneer horns are factory loaded with them, they are the go to recommendation for the keystone, among others. I wouldn't say they are exclusive to reflex but I heard about poor back loading performance, unfortunate, they are a killer driver
