  New Posts New Posts RSS Feed - Elements audio amplifier ck26
kilowattsounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kilowattsounds Quote  Post ReplyReply Direct Link To This Post Topic: Elements audio amplifier ck26
    Posted: 06 March 2023 at 6:24pm
Has anyone tried one on bass duty ? Results ?
MORE BASS LESS BEEF INCREASE THE PEACE !!!!!
my facebook page
Sypa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 06 March 2023 at 10:45pm
I havent but +1 for interest , actually looking more at the k2200 which isnt in the elements range but same manufacturer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kilowattsounds Quote  Post ReplyReply Direct Link To This Post Posted: 07 March 2023 at 8:29am
Research time I think 🤔
my facebook page
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 07 March 2023 at 12:43pm
Word of advice 'bredrin..
In testing, Macrotech MA3600VZ, ran out of steam trying to drive 4 ohm 1852 on 1x channel.
That was proper 1500W, from respected Transformer amp, not enough for "1KW" driver.
So really "suggest", you "test" any lightweight of interest, before buying.
EDIT:Also just remembered, Kutty told me, Bridged QSC 4050HD, across 2x 8 ohm PD1852, "Clipped", before powering drivers to their full potential.
Further example, of very serious amps needed, to fully power big man drivers, for Roots Reggae.
Edited by levyte357- - 08 March 2023 at 9:45am
Post Options Post Options   Thanks (0) Thanks(0)   Quote kilowattsounds Quote  Post ReplyReply Direct Link To This Post Posted: 08 March 2023 at 11:13am
Nice one Lev 👍🏿 I'm just doing a bit of research before jumping in
my facebook page
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 08 March 2023 at 11:57am
No problem sah.
Many don't know, in many designs of cabs, total impedance of cab + driver, exceeds nomial impedance of just driver.
E.g. 2x Scoops loaded with 8 ohm driver each, can be seen on Powersoft K20 DSP,
as "6 ohm load", not 4 ohms as expected !!!
So if total impedance per channel exceeds expectation, situation is agravated, by sub amplifier not producing output power at 40hz, that is in specs, for 1khz burst.
Which is why many lightweights rated at 4K per channel @ 4 ohms, are outperformed by Void Inf8 Mk2, which is rated at 2.5kwpc @ 4 ohms.
In summary, if not buying Powersoft, get most respected, most powerful, lightweigh sub amp you can afford, and test before buying.
Edited by levyte357- - 08 March 2023 at 12:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote kilowattsounds Quote  Post ReplyReply Direct Link To This Post Posted: 08 March 2023 at 1:23pm
Some good advice there bredrin much appreciated 👏
my facebook page
