  New Posts New Posts RSS Feed - Eminence Killomax Pro 18 Plan
tb_mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 03 October 2005 at 11:09pm
Originally posted by ToXiC ToXiC wrote:
No the kilomax would sound crap in scoops.
I'd say the C-sub where it says you can use them as one of the drivers to choose from.
Toxic: ported/bp6 will be real boomy with this woofer. Thiele,or some one like him reccomended Qts<0.45 or something. Maybe he wants boom tho ;-)
Tom Umney View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Umney Quote  Post ReplyReply Direct Link To This Post Posted: 04 October 2005 at 11:50pm
Well Rog on those plans says the Eminence Kilomax can be used in the C-sub.
Although generally Eminence Kilomax is pretty unsuitable for most boxes.
Edited by ToXiC
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 05 October 2005 at 4:44am
That driver will sound much better in a BP4 than a BP6A.
djk
Lasse Lukkari View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lasse Lukkari Quote  Post ReplyReply Direct Link To This Post Posted: 05 October 2005 at 8:06am
Rog also said that he doesn't recommend it anymore.
horatioa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote horatioa Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2006 at 12:13am
I Think They Would Work Very Well In The EV T18 Design With A Little Modification, Can Some One Share Their Technical Expertise, Another Thing Electro Voice Had Modified The T18 To The SB180.
Spinners Choice
Post Options Post Options   Thanks (0) Thanks(0)   Quote horatioa Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2006 at 12:22am
What Is The BP4
Spinners Choice
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2006 at 1:48am
A 4th order bandpass enclosure (BP4). Similar to the 'C' sub shown above, but with only one chamber ported.
The 'C' sub is a BP6A, a BP6B has a port from one chamber to the other, and then one port to the outside.
All three types are sensitive to the T/S parameters of the drivers, and no substitutes should be made without checking in a box modeling program.
The Kilomax 18 does not model well in a BP6A.
Edited by _djk_ - 26 March 2006 at 1:51am
djk
Insomnia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Insomnia Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2006 at 9:05am
dont bother putting kilomax's in T18's mate
Post Options Post Options   Thanks (0) Thanks(0)   Quote mobiele eenheid Quote  Post ReplyReply Direct Link To This Post Posted: 31 March 2006 at 10:12am
I did model Kilomax in 6th order BP(A) (iirc something like 120 ltr tuned to 45 Hz and 80 ltr to 75 Hz) it did look pretty impressive SPL-wise and powerhandling, just horrible groupdelay.
My guess would be that it will sound much better if the second chamber is around 40 ltr tuned to 200 -300 Hz. Would behave like BP6/BR-hybride. Less SPL but much less groupdelay and less peaky aswell. Also less distortion from cone movement.
Wkr Johan
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 31 March 2006 at 10:01pm
The group delay is simply a function of the frequency response.
A simple sealed box with a low-pass filter of the same roll-off rate and same frequency has the same group delay.
djk
