ES15BPH ? |
Page <123 |
| Author | ||||
Tocooltom
Joined: 07 March 2011 Location: London Status: Offline Points: 1370 |
Posted: 27 July 2012 at 11:42am |
Any chance anyone can PM me a link to these plans?
levyte357
Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11743 |
Posted: 27 July 2012 at 11:49am |
TBH, I think the TSE 115 plan would sound better. |
Keen
Joined: 30 May 2011 Location: Brisbane, Aus Status: Offline Points: 1271 |
Posted: 27 July 2012 at 12:48pm |
if you didn't already see this Tom
http://imageshack.us/photo/my-images/40/pd156kick.jpg/ from nomis23 on here. Driver is PD156 |
Tocooltom
Posted: 27 July 2012 at 12:53pm |
Thanks ![]() where it says internal dimension 50cm, is that the width of the internal panels? (so the cab would be 500mm wide plus 32mm for the side panels?) or the overall width including the side panels?
Keen
Posted: 27 July 2012 at 1:05pm |
yeah wondered this too. I read it as 500mm internal panels with overall width @ 536.
here's the thread it came from too http://forum.speakerplans.com/es15-bph_topic27238_page2.html |
Tocooltom
Posted: 27 July 2012 at 2:18pm |
yeh my mistake 36mm
Keen
Posted: 27 July 2012 at 2:47pm |
yeah nice one...
![]() dilwang ![]() |
Keen
Posted: 28 July 2012 at 10:53am |
anjmoor
Joined: 28 August 2012 Location: south east Status: Offline Points: 40 |
Posted: 28 August 2012 at 6:44pm |
Hi all been lurking here for a while, I have dry built an ES-15 cab and modded it to sit on a cubo 15, did a sound test with all the sealed chamber joints taped and must say that I was quite satisfied so far with what i was hearing, these def dont go as high as an 18 but I think I had them running up to 160 before they started honking. great punch from them tho.
mousaka
Joined: 04 September 2012 Status: Offline Points: 28 |
Posted: 01 November 2015 at 5:47am |
I have 4 X PD154 that i had mounted in hd15, only I don't like the sound of hd15
i find it too dry for me I look for a plan that will go down lower Do you have any suggestions and plans to share me please? |
tv00
Joined: 10 August 2009 Location: Denmark Status: Offline Points: 1886 |
Posted: 16 December 2015 at 1:05pm |
TSE 115 will do 280hz, it's used up to 250hz in the tms-2, but it does 280hz better than the tse-118 that is crossing at 280hz in the tms-4. PD.1550 is NOT the right driver in TSE-115, it's more of a subdriver. I testet this, I measured, (blind) listened & simulated to find proper drivers for my tms-2s Rcf mb15n401 won, it even sounded better than the original turbodrivers. The fane studio 15b sound very good in there to, has a bit more punch / peak. The rcf is a 4" coil driver, but this doesn't seem to be decisive for what driver to use, I'm sure some of the 3" rcf drivers will do very well, mb15n351 & mb15n301. If you want to why don't you just downscale the es18bph & do a sim? -Should work! The Turbosound Aspect wide & Funktion one RES-2 are also rearloaded. |
Page <123 |
