ES18-BPH |
Page <12345 35> |
| Author | ||
Buffmarley
Joined: 06 February 2008 Location: United Kingdom Status: Offline Points: 182 |
Posted: 04 June 2009 at 12:56pm |
not enough: Bridge Mode-Mono: 8 Ohms: 1800 Watts RMS
maybe on paper but not enough in practice |
double fred
Posted: 18 June 2009 at 1:08pm |
Was quite unhappy with how it was run at the last frenchtek. dodgy console splitting the signal between various racks meant I couldn't send a summed signal to my bass amps. As if the stereo signal was out of phase. annyway, ours are loaded with p.audio C18-650EL and each double bin gets 1400w @ 4ohm from a Lab Gruppen 2000c channel. we run a stack of 6 (so 12 x C18-650EL drivers) 42hz-168hz precisely, there's no eq or anything else, just limiters (must do a proper SMAART session sometimes). for feewer cabs I up the low cut off point to 45-48. I've never had a chance to do a proper A-B test with the FK1 218 but after having listened to both or them for a long time at Boom festival last year, I think our double ES-18BPH sounds better and just as loud ![]() What with them using one of the cheapest off the shelve 18" driver, and very little wood for a bass bin. Overall we're very very pleased with our choice of bass bins, except shortly after our first build, p.audio announced the MKII, with new TS and power handling ![]() I for one gonna have to buy some 2nd hand C18-650EL at some point. |
sKs01
Joined: 11 April 2008 Location: sheffield Status: Offline Points: 1744 |
Posted: 18 June 2009 at 1:17pm |
we use pd186 in our es18's and i realy like the sound, not had a proper chance for compartivive listening other than with 1 oem turbosound driver which can neither be baught nor reconed.
for those using es18 as sub bring the crossover up higher, it wont produce the low end anyway and your just eating up the power of the amp producing low end content out of the passband of the box. i tried this myself having the crossover down at 20Hz and then bringing it up to 80HZ or so the signal light dropped on the amp from fullly on all the time to barley glinting and then turned the gains up and was met by a ton of kick. you might be able to scrape another db or two out of them that way and if you have something go wrong your less likley to break the driver.
Edited by sKs01 - 18 June 2009 at 1:22pm |
SwenK
Joined: 04 February 2009 Location: Cornwall Status: Offline Points: 207 |
Posted: 21 June 2009 at 1:26pm |
Double Fred
Is the driver still suitable?
I assume the only reason you couldn't use the new drivers with the old just because of mixing drivers in the same band?
cheers
s.
It's an artistic piece...but i like it
djslacka
Posted: 25 June 2009 at 9:55am |
has anyone tried using a fane colossus 18xb in es18s? we have some that need a new home and apart from scoops or reflex they seem to be useless for everything else!
double fred
Posted: 25 June 2009 at 2:48pm |
new TS, doesn't mean it won't work but the original plan has been designed with different TS in mind. anyway, the new drivers are rated at 850w I think, so my amps aren't quite powerfull enough to drive them (as opposed to the old 650w driver whih is just perfect for the amps). |
biotec
Joined: 07 June 2004 Location: United Kingdom Status: Offline Points: 2932 |
Posted: 25 June 2009 at 2:56pm |
fred I heard the cabs at the teknival in France in may 2008. I saw your sound system setting up this year but didn't find you again!
It is the best I have heard those drivers sound. I think the £ to performance ratio is excellent.
Mircea Bartic
Joined: 18 February 2005 Location: Romania Status: Offline Points: 2589 |
Posted: 25 June 2009 at 3:47pm |
tested the new C18ELF in the ES18BPH , and found out is sounds better and goes a bit lower |
Meat
Joined: 05 June 2009 Location: Manc Status: Offline Points: 1513 |
Posted: 25 June 2009 at 4:29pm |
Anyone got any of these in Sheffield or Manchester?
Me and a mate are thinking about building some and loading them with some RCFs hes got and we'd like to try the drivers in the cabs before doing the build. The sims look real good and they seem to go to 40Hz ok (but not flat) just want to see if the reality is anything like the sim. |
djslacka
Posted: 03 July 2009 at 10:04am |
has anyone tried using fane colossus 18xb in es-18s? i heard that they sound ok in usbs and i know they arent the same box exactly, but would it work?
double fred
Posted: 03 July 2009 at 2:38pm |
you heard this : ![]() ![]() and this is where we stand now : ![]() ![]() causing damage + a 508D in the back éé!We use those TMS4 because we had them sitting in the lockup, I don't like their sound much, the mid-high is weak to my ears and furthermore the bottom section works in the same freq band as our bass bins. I'd like to build 2 more "porn horn V1", and stack the bass bins 2 wide 3 high underneath, would be a nice compact 10kw. |
Sequence Empire:::..
Joined: 13 January 2009 Location: New Zealand Status: Offline Points: 84 |
Posted: 04 July 2009 at 11:58pm |
Been thinking this is going to be the way to go for the low end under my 4 MT121's. I have access to SD-18's here in New Zealand, so it'd work out 2 stacks of ES-218's 3 high each side with 2 MT121's above per stack. I have not found any info on how the SD-18's perform other than they have slightly more output & can extend lower than the C-18's in the ES18 cab... Anyone know what low freq response a set-up like this should do? I'm interested in the Stapier design as it appears simple in construction & figures/opinions on here are positive, my only problem is I have never heard them before so walking in the dark a little here to firm up what to build. James Edited by Sequence Empire:::.. - 05 July 2009 at 12:10am |
Page <12345 35> |
