  New Posts New Posts RSS Feed - Fane scaled up
Fane scaled up
 Post Reply Post Reply Page  <1 11121314>
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 22 September 2023 at 4:02pm
someone once said a gap of at least the diameter of the vent on the back of the driver...
Would say, primarily, the chamber must be tuned to the driver in terms of Vas & Qes, and the volume of the driver, must be taken into consideration.
For the the people who just want drop any old driver, in any old cab, you will pay in recones, till you get it  right, or learn how to match drivers to cabs, by T/S parms.
APSUS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote APSUS Quote  Post ReplyReply Direct Link To This Post Posted: 22 September 2023 at 10:14pm
Would 46mm work?
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 23 September 2023 at 11:45am
Originally posted by APSUS APSUS wrote:
Would 46mm work?
I know someone selling proven 18" Scoops  that work with PD1851/18NLW9601/B&C 18DS100, and similar drivers.
Edited by levyte357- - 23 September 2023 at 11:50am
valve head777 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote valve head777 Quote  Post ReplyReply Direct Link To This Post Posted: 23 September 2023 at 11:54am
Can we have a new topic where people are free to advertise their own products.
Apparently there's only one relevant scoop design these days.
Post Options Post Options   Thanks (0) Thanks(0)   Quote APSUS Quote  Post ReplyReply Direct Link To This Post Posted: 25 September 2023 at 3:22pm
Response from 18 Sound
“The clearance can be very small, like one inch or even less, it will not affect the speaker performances.
Just be sure that the magnet or the metal parts are not touching the wood or the dampening material”.
Regards
Francesco Mazzini
18S R&D
KDW32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KDW32 Quote  Post ReplyReply Direct Link To This Post Posted: 26 September 2023 at 6:27pm
How many chambers does it have 5 maybe 6 the most powerful scoop in the world! So do you feel lucky Dread? This the Lev .44  magnum.
Edited by KDW32 - 26 September 2023 at 7:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote valve head777 Quote  Post ReplyReply Direct Link To This Post Posted: 26 September 2023 at 7:19pm
Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote APSUS Quote  Post ReplyReply Direct Link To This Post Posted: 31 December 2023 at 4:52pm
As per below.
Edited by APSUS - 31 December 2023 at 4:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote APSUS Quote  Post ReplyReply Direct Link To This Post Posted: 31 December 2023 at 4:53pm
Not sure what you're asking Junior?
if you want a larger chamber of 70 litres the rear baffle length would be 394mm as above post
do you need both throat areas of both chamber sizes?
So is the recommended size 394mm or 425mm for the rear panel if using a PD1850 or PD1852.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 04 January 2024 at 9:27am
Original plan without mod, is fine for PD1850.
But then, IMHO, these days, an 1850 loaded Scoop, would be quite mediocre, compared to Scoop loaded with compatible, modern driver.
Edited by levyte357- - 04 January 2024 at 9:58am
StoneCutter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StoneCutter Quote  Post ReplyReply Direct Link To This Post Posted: 17 June 2025 at 8:27pm
Hi all. I came into possession of 4 18" scoop cabs a while ago, but only recently took them out of storage to properly inspect them and take some measurements. The height and depth are 1220mm and 720mm respectively, and this along with the flat former at the bottom of the chamber indicate that they could be based on this scaled up Fane design.
However, the external width is only 590mm, which, as I understand from reading about this scaled up Fane plan on the forum, is a bit narrower than the 60 - 61cm recommended. It seems that someone has tried to make an already small chamber even smaller as the depth of the front chamber is 185mm instead of 190mm.
I haven't had chance to test them out yet, but my intention is to refurbish them and probably load them with 1852s.
What I would like to know is if these smaller dimensions would present any problems or issues that you more experienced members might know of. I'm a long time lurker of this forum but have only just made an account as I'm now looking to complete a full system and am hoping to pick some brains if that would be okay.
Cheers
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 18 June 2025 at 4:08pm
There is a difference between a driver working in a Scoop, and excelling.
Personally, in this day and age, I wouldn't bother with any Scoop < 636mm wide.
Smaller width, means smaller horn mouth, and all the loss in SPL, that brings.
The days of compromising build size, to save on sheets of ply are over.
