Fane scaled up |
Page <1 121314 |
StoneCutter
Joined: 17 June 2025 Location: Nottingham, UK Status: Offline Points: 2 |
Posted: 18 June 2025 at 4:25pm |
Hi Levyte. Appreciate your response.
Okay, so I understand that they aren't at all optimal. However, they are already built and hold some sentimental value so binning them off is not an option on the table. I think I can live with sacrificing a few dBs, so I'll see how they do, and maybe return with some results after testing them out.
levyte357-
Joined: 27 July 2012 Location: UK, South East Status: Offline Points: 8517 |
Posted: 18 June 2025 at 7:45pm |
Do hear that, but have to say, getting some money for them if possible, and building the Mykey Fane plan scaled up, with width 636mm, would be be better home for modern drivers. EDIT:Remembering, increasing cab width, not only increases horn mouth, but also chamber size, horn throat area.
Edited by levyte357- - 18 June 2025 at 7:53pm |
Serenerock
Joined: 11 November 2025 Location: Uk Status: Offline Points: 4 |
Posted: 29 December 2025 at 9:12pm |
Hi levy, please is this design for fans 18xb colusus?
Can you help me with a fane colusus scoop plan for 18 inches Edited by Serenerock - 29 December 2025 at 9:36pm |
Serenerock
Posted: 29 December 2025 at 9:23pm |
Hi Mykey,
I just acquired 8 fane colusus 18xb.can you please help me with the fane 18 scoop design.
stitchie
Posted: 11 January 2026 at 9:56am |
how many hz would 4x play down to using PD1850 mk1 driver. Thanks
levyte357-
Posted: 15 January 2026 at 9:02pm |
Depends on the power, you intend to play. I would suggest set HPF to 38hz.
In a stack of 4x, that will sound like 32hz. |
levyte357-
Thanks(1)
Posted: 15 January 2026 at 9:03pm |
Fane 18XB are not very strong, I would suggest at least PD1850 MK1/MK2.
Noah R.O.B.
Joined: 25 January 2026 Location: Switzerland Status: Offline Points: 1 |
Posted: 26 January 2026 at 1:21pm |
[/QUOTE] Hi mr Lev from what i’ve understood by reading this thread me and my mate unfortunately have built the wrong box for the driver we bought, we’ve loaded a PD185C003 in a super scoop. We had no real knowledge, and went for the box everyone else had around us. I assume this project but 636 mm wide would be better for our driver, since you have told different people that modern drivers will probably behave better in this cab. Correct me if i’m wrong
Skills
Joined: 11 June 2016 Location: london Status: Offline Points: 20 |
Posted: 20 March 2026 at 9:43pm |
![]() Hi chaps sorry for the silly questions but can someone explain to me how to get the measurements for the sections highlighted in green please. Cheers Edited by Skills - 20 March 2026 at 10:19pm |
Jah Jah Rule. String up or Shut UP !!
Contour
Posted: 21 March 2026 at 8:00am |
To me looks possible you can determine this from the other dimension and angle.
monkeypuzzle
Joined: 25 January 2005 Status: Offline Points: 1046 |
Posted: 21 March 2026 at 10:32am |
Cut a side out of some scrap or 12mm ply and use this as a guide. Draw all lines on it and you can then take measurements for anything not marked. There's enough info there to do this. As you cut pieces, use this to confirm that each piece is correct.
levyte357-
Posted: 21 March 2026 at 10:41am |
Yes, this.cab will most likely be best for your drivers.
Page <1 121314 |
