  New Posts New Posts RSS Feed - Fane scaled up
Fane scaled up
 Post Reply Post Reply Page  <1234 14>
mykey- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey- Quote  Post ReplyReply Direct Link To This Post Posted: 21 December 2012 at 7:00pm
Yeah that info is already there
JR.junior View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR.junior Quote  Post ReplyReply Direct Link To This Post Posted: 21 December 2012 at 7:02pm
Ok, for the inner width 60-61cm? If so, thx mate!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey- Quote  Post ReplyReply Direct Link To This Post Posted: 21 December 2012 at 7:04pm
internal would be 574mm for a 610mm cab
Tre4u2nv will probably be along in a min and tell you how the standard (first drawing) scaled up Fanes I had sounded
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR.junior Quote  Post ReplyReply Direct Link To This Post Posted: 21 December 2012 at 7:31pm
Not really because we are only talking shortening the horn by very minor amounts. This design scoop will never be one-notey. And chamber size will increase not decrease.
Here's an easier one.....if you shorten/adjust the bottom of chamber panel that is now 209mm to 123mm wide this will give you a rear chamber size of 58 litres minus the driver and a throat area of 780. I would favour that mod. Thumbs Up see below. This could be used on both deeper and standard scoop if newbies don't understand.
SBC who is Saul has just had some Fane scoops built. Don't suppose he would tell us what mod he has done but it would be interesting if there are any of the above been usedThumbs UpWink
aha, I mised that one, superb! I like tight cmaber and thorat scoop sound. PD1850 loaded. In this drawing I would go for rear panel 500mm, second panel 500mm and 10 degress slope = slower expansion. SPL guaranteed!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey- Quote  Post ReplyReply Direct Link To This Post Posted: 21 December 2012 at 7:37pm
This is not my design Junior. It wasn't really to be adjusted in that way. It's already a proven design as I used to use them 22 years ago. To make the adjustment of 10 degree slope that you mentioned you may as well design a new scoop for SPThumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR.junior Quote  Post ReplyReply Direct Link To This Post Posted: 21 December 2012 at 7:44pm
hehe, nuff respect man! Thumbs Up
SBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SBC Quote  Post ReplyReply Direct Link To This Post Posted: 21 December 2012 at 9:36pm
come on now, can't be giving secrets like that away.
F.T.S.S.
soundchippy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote soundchippy Quote  Post ReplyReply Direct Link To This Post Posted: 22 December 2012 at 12:08am
Hi Chaps
I had 16 of these around 1989. I had great pleasure with them. They were loaded with the Fane 400 Colossus. Pretty scary when all 16 were running....ask Tre4u2nv LOL
Anyways, I have drawn up 2 versions. One as standard and the other with a double baffle and segmented scoop.
Second version is also slightly deeper, as well as a deeper chamber to receive deeper drivers
Width should be 61cm (24'')... do the cab wider to gain a larger chamber
chamber is 57 litres without the driver
Handle placements and cut off rear for castors is up to you to do
I'm 100% sure that with the Royals and the new monster Fanes these will sing
  EnjoyTongue
Thanks for the plan. Please could you re-do dimensions. At present it is very sloppy and hard to read.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey- Quote  Post ReplyReply Direct Link To This Post Posted: 22 December 2012 at 4:04am
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey- Quote  Post ReplyReply Direct Link To This Post Posted: 22 December 2012 at 4:07am
Soundchippy. Bit confused as to what file to save them in. I'm coming from autocad - copy paste to paint, then saving. First time I saved them before the adjustment they came out quite sharp. Saved them again and the came out blurry as you can see. Any suggestions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey- Quote  Post ReplyReply Direct Link To This Post Posted: 22 December 2012 at 4:08am
Sorry, screen save not copy, then paste to paint
Post Options Post Options   Thanks (0) Thanks(0)   Quote soundchippy Quote  Post ReplyReply Direct Link To This Post Posted: 22 December 2012 at 11:08am
Try printing to PDF then taking screen grab.
