Fane scaled up |
Page <12345 14> |
SBC
Joined: 25 November 2010 Status: Offline Points: 1266 |
Posted: 22 December 2012 at 11:09am |
if your using autocad, go to paper space (layout 1), select the box there, and stretch it to the extents of the paper. the dotted line will show your printable area. usually the paper size will be a4 default, but if not, you need to right click on the layout tab, and go to "page setup manager"
then double click in the box (viewport) and zoom in on the area you want. you can select specific scales on the drop down bottom right of screen. double click outside viewport to finish. then go to output ----> pdf -----> save to a place. or type plot, and there's usually an option to save as pdf instead of print. screen shots from autocad is not the way to keep plans legible. ![]() p.s. you can also plot by just typing plot, whilst in model space. select "window" from the "what to print" drop down. select your window. select your scale, and then print to pdf.
Edited by SBC - 22 December 2012 at 11:13am |
F.T.S.S.
mykey-
Joined: 03 March 2010 Location: ID/UK Status: Offline Points: 6119 |
Thanks(1)
Posted: 22 December 2012 at 11:16am |
Cheers Saul
mykey-
Posted: 22 December 2012 at 11:23am |
Edited by mykey- - 22 December 2012 at 11:45am |
mykey-
Posted: 22 December 2012 at 11:47am |
soundchippy
Joined: 09 September 2011 Location: Tavistock Status: Offline Points: 770 |
Posted: 22 December 2012 at 10:28pm |
If you fancy fowarding me the DWG i'll have a go at sorting it.
SBC
Posted: 22 December 2012 at 10:59pm |
a screen print being saved as a pdf isn't the same as an output from auto cad, if this is what is being done.
F.T.S.S.
mykey-
Posted: 23 December 2012 at 5:37am |
No that's not what I'm doing
I'll get a screen shot of what autocad is saying |
mykey-
Posted: 23 December 2012 at 5:49am |
![]() so the font used for the degree text is ArialIMT. I can't seem to change that font |
mykey-
Posted: 23 December 2012 at 5:50am |
Upgrade Adobe?
SBC
Posted: 23 December 2012 at 1:20pm |
type command:
DIMSTYLE to change the dimension text type and several other parameters |
F.T.S.S.
mykey-
Posted: 23 December 2012 at 3:00pm |
no been there many times. It won't change the font for the degree text
anyways, I'll sort it cheers |
bee
Joined: 14 June 2011 Location: Middlesex Status: Offline Points: 4549 |
Posted: 02 January 2013 at 1:27pm |
can u not just over lay the deg font in photoshop..... so save a jpg in cad, open in photoshop and add missing type.....
Edited by bee - 02 January 2013 at 2:48pm |
Page <12345 14> |
